I have flashed Octopi on and SD card and when I try to open it to configure the "octopi-wpa-supplicant.txt" file it says SD card is empty. I have tried etcher and win32 disk imager with same results. What am I doing wrong.
Hello @freeon!
I assume that Etcher and Win32 gave a positive feedback after flashing.
Did Windows complain and asked you to format the SD card?
Yes Etcher said flash successful. After it was done windows said i needed to format SD, which i didn't.
Did you try to remove the card and put it back in?
Maybe it was ejected by etcher
Yes. Even tried a different PC.
