SD resolution for 1080p camera
Raspberry Pi Camera v2
I have a raspberry pi camera v2 connected to a Raspberry Pi 3b, and the camera only streams in 480p.
Changed the octopi.txt camera_raspi_options to 1080p fps 10, but nothing changes.
Yes.
No, still running in SD 480p
octoprint-systeminfo-20231016155601.zip (45.8 KB)
Running Ender-3 V2/S1 Professional Firmware 20230904
Running Octoprint version 1.9.3, Octopi version 1.0.0
Looks like your running the newer version of octopi which no longer uses octopi.txt.
You will need to have a look in the camera streamer folder and modify the libcamera.conf file
Have a read here - A new camera stack for OctoPi - Blog - OctoPrint Community Forum
and here - Camera-streamer configuration on the new camera stack for OctoPi - Get Help / Guides - OctoPrint Community Forum
Strange, I didn't have the 'camera-streamer' folder in /boot.
I don't believe you are running the version of OctoPi with the new camera stack.
If you don't have a lot of "extra" applications, I'd suggest that you create an OctoPrint backup and reimage your microSD card with the new camera stack image. You can find it at https://octoprint.org/download/ or in the Raspberry Pi Imager.
(For information purposes only, I'd also recommend the new stack)
camera_raspi_options does not exist in OctoPi 1.0.0. All cameras use the camera_usb_options line now, since raspi support was dropped. The cameras work as "usb" cameras, which underneath means they use the same driver - calling it "usb" is misleading, but it's not going to be changed when the new stack is where development should be focused.
