Camera model Insta360 One R, 4K mod
What is the problem? Cannot find a configuration that will work for the Insta360 One R camera. (Logitech camera works fine.) When I test /webcam2/?action=stream in octoprint settings, I get a broken-image icon next to the text that says: If you see your webcam stream below, the entered stream URL is ok. I have also tried this with only the Insta360 camera installed, and with the camera_usb_options mentioned below moved to the /boot/octopi.txt file. Of course v4l-ctl output is adjusted accordingly, but that is the only change. No joy.
What did you already try to solve it? In /boot/config.txt, set camera="usb" and camera_usb_options="-r 1920x1080 -f 30 -d /dev/v4l/by-id/usb-Amba_Insta360_One_R-video-index0" (I also tried -f 10, to no avail)
Logs (/var/log/webcamd.log, syslog, dmesg, ... no logs, no support) (I do not see such a file. /etc/default/webcamd indicates that such a file should be created, but it is not in /var/log as it should be although this is in that file: LOG=/var/log/webcamd.log
I will be thrilled to share that file if we can make it appear.
Additional information about your setup (OctoPrint version, OctoPi version, ...) OctoPrint 1.6.1, Octopi 0.17.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
output from v4l2-ctl --list-devices
bcm2835-codec-decode (platform:bcm2835-codec):
/dev/video10
/dev/video11
/dev/video12
bcm2835-isp (platform:bcm2835-isp):
/dev/video13
/dev/video14
/dev/video15
/dev/video16
Logitech Webcam C930e (usb-3f980000.usb-1.1.2):
/dev/video0
/dev/video1
Insta360 One R: Insta360 One R (usb-3f980000.usb-1.3):
/dev/video2
/dev/video3
Created a directory /boot/octopi.conf.d
List of camera devices:
ls -l /dev/v4l/by-id/
total 0
lrwxrwxrwx 1 root root 12 Nov 30 20:20 usb-046d_Logitech_Webcam_C930e_0DDAA26E-video-index0 -> ../../video0
lrwxrwxrwx 1 root root 12 Nov 30 20:20 usb-046d_Logitech_Webcam_C930e_0DDAA26E-video-index1 -> ../../video1
lrwxrwxrwx 1 root root 12 Nov 30 20:37 usb-Amba_Insta360_One_R-video-index0 -> ../../video2
lrwxrwxrwx 1 root root 12 Nov 30 20:37 usb-Amba_Insta360_One_R-video-index1 -> ../../video3
Content of /boot/octopi.conf.d/webcam2.txt:
camera="usb"
camera_http_webroot="-n -p 8081"
camera_http_options=""
I have also modified /etc/haproxy/haproxy.conf:
global
maxconn 4096
user haproxy
group haproxy
log 127.0.0.1 local1 debug
defaults
log global
mode http
option httplog
option dontlognull
retries 3
option redispatch
option http-server-close
option forwardfor
maxconn 2000
timeout connect 5s
timeout client 15min
timeout server 15min
frontend public
bind :::80 v4v6
bind :::443 v4v6 ssl crt /etc/ssl/snakeoil.pem
use_backend webcam2 if { path_beg /webcam2/ }
default_backend octoprint
backend octoprint
acl needs_scheme req.hdr_cnt(X-Scheme) eq 0
reqrep ^([^\ :]*)\ /(.*) \1\ /\2
reqadd X-Scheme:\ https if needs_scheme { ssl_fc }
reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc }
option forwardfor
errorfile 503 /etc/haproxy/errors/503-no-octoprint.http
backend webcam
reqrep ^([^\ :]*)\ /webcam/(.*) \1\ /\2
server webcam1 127.0.0.1:8080
backend webcam2
reqrep ^([^\ :]*)\ /webcam2/(.*) \1\ /\2
server webcam2 127.0.0.1:8081
errorfile 503 /etc/haproxy/errors/503-no-webcam.http[logs.zip|attachment](upload://8Ug1Y9u8HJdd5eyMpoWNUXXXb4T.zip) (122.3 KB)
