No serial port found
Reconnect usb cable
Tried in different usb ports
Yes, no difference
octoprint-systeminfo-20231126102838.zip (28.0 KB)
dmesg info
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 6.1.21-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP Mon Apr 3 17:22:30 BST 2023
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] random: crng init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] percpu: Embedded 17 pages/cpu s36884 r8192 d24556 u69632
[ 0.000000] pcpu-alloc: s36884 r8192 d24556 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 489792
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:39:5B:72 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=9d55f89b-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000009a00000-0x000000000da00000] (64MB)
[ 0.000000] Memory: 1337616K/1966080K available (10240K kernel code, 1502K rwdata, 3128K rodata, 2048K init, 634K bss, 104176K reserved, 524288K cma-reserved, 1179648K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 37084 entries in 109 pages
[ 0.000000] ftrace: allocated 109 pages with 5 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000016] Switching to timer-based delay loop, resolution 18ns
[ 0.000333] Console: colour dummy device 80x30
[ 0.000846] printk: console [tty1] enabled
[ 0.000906] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000945] pid_max: default: 32768 minimum: 301
[ 0.001071] LSM: Security Framework initializing
[ 0.001252] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001291] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002499] cgroup: Disabling memory control group subsystem
[ 0.002701] CPU: Testing write buffer coherency: ok
[ 0.002760] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.003117] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004048] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004078] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004212] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004361] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004532] rcu: Hierarchical SRCU implementation.
[ 0.004554] rcu: Max phase no-delay instances is 1000.
[ 0.005304] smp: Bringing up secondary CPUs ...
[ 0.006234] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007227] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008218] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.008337] smp: Brought up 1 node, 4 CPUs
[ 0.008399] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.008423] CPU: All CPU(s) started in HYP mode.
[ 0.008441] CPU: Virtualization extensions available.
[ 0.009062] devtmpfs: initialized
[ 0.020518] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.020727] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020771] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.035046] pinctrl core: initialized pinctrl subsystem
[ 0.036065] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.039023] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.039621] audit: initializing netlink subsys (disabled)
[ 0.039840] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.040397] thermal_sys: Registered thermal governor 'step_wise'
[ 0.041025] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.041071] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.041436] Serial: AMBA PL011 UART driver
[ 0.050183] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.070038] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:51:33, variant start_x
[ 0.080052] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.121865] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.128148] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.132115] SCSI subsystem initialized
[ 0.132332] usbcore: registered new interface driver usbfs
[ 0.132394] usbcore: registered new interface driver hub
[ 0.132456] usbcore: registered new device driver usb
[ 0.132706] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.132867] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.133134] pps_core: LinuxPPS API ver. 1 registered
[ 0.133157] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.133197] PTP clock support registered
[ 0.134110] vgaarb: loaded
[ 1.393791] clocksource: Switched to clocksource arch_sys_counter
[ 1.394584] VFS: Disk quotas dquot_6.6.0
[ 1.394674] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.394825] FS-Cache: Loaded
[ 1.395005] CacheFiles: Loaded
[ 1.428412] NET: Registered PF_INET protocol family
[ 1.428701] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.430526] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 1.430584] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.430683] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.430758] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 1.430906] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.431053] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.431106] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.431303] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.431824] RPC: Registered named UNIX socket transport module.
[ 1.431853] RPC: Registered udp transport module.
[ 1.431873] RPC: Registered tcp transport module.
[ 1.431891] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.431921] PCI: CLS 0 bytes, default 64
[ 1.433633] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.477283] Initialise system trusted keyrings
[ 1.477623] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.484583] zbud: loaded
[ 1.486748] NFS: Registering the id_resolver key type
[ 1.486794] Key type id_resolver registered
[ 1.486815] Key type id_legacy registered
[ 1.486925] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.486951] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.488016] Key type asymmetric registered
[ 1.488043] Asymmetric key parser 'x509' registered
[ 1.488284] bounce: pool size: 64 pages
[ 1.488428] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.488626] io scheduler mq-deadline registered
[ 1.488651] io scheduler kyber registered
[ 1.490103] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 42)
[ 1.495446] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.495497] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.495573] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.495644] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[ 1.496509] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.496539] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.496567] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.496639] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.496792] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.499774] PCI: bus0: Fast back to back transfers disabled
[ 1.499804] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.499990] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.500159] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.500254] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.565901] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.566061] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.566184] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.566534] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.567022] PCI: bus1: Fast back to back transfers disabled
[ 1.567049] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.567097] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.567130] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.567219] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.567246] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.567518] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.567709] pcieport 0000:00:00.0: PME: Signaling with IRQ 46
[ 1.577976] iproc-rng200 fe104000.rng: hwrng registered
[ 1.578239] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.579212] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.589270] brd: module loaded
[ 1.596162] loop: module loaded
[ 1.596750] Loading iSCSI transport class v2.0-870.
[ 1.600717] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.693892] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.694870] usbcore: registered new interface driver r8152
[ 1.694944] usbcore: registered new interface driver lan78xx
[ 1.695007] usbcore: registered new interface driver smsc95xx
[ 1.742630] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.742684] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.746690] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
[ 1.747610] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.747645] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.747680] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.747964] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.747999] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.748027] usb usb1: Product: xHCI Host Controller
[ 1.748049] usb usb1: Manufacturer: Linux 6.1.21-v7l+ xhci-hcd
[ 1.748071] usb usb1: SerialNumber: 0000:01:00.0
[ 1.748645] hub 1-0:1.0: USB hub found
[ 1.748706] hub 1-0:1.0: 1 port detected
[ 1.749376] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.749412] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.749441] usb usb2: Product: xHCI Host Controller
[ 1.749462] usb usb2: Manufacturer: Linux 6.1.21-v7l+ xhci-hcd
[ 1.749484] usb usb2: SerialNumber: 0000:01:00.0
[ 1.749993] hub 2-0:1.0: USB hub found
[ 1.750054] hub 2-0:1.0: 4 ports detected
[ 1.751313] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.751527] dwc_otg: FIQ enabled
[ 1.751537] dwc_otg: NAK holdoff enabled
[ 1.751546] dwc_otg: FIQ split-transaction FSM enabled
[ 1.751559] Module dwc_common_port init
[ 1.751921] usbcore: registered new interface driver uas
[ 1.752028] usbcore: registered new interface driver usb-storage
[ 1.752213] mousedev: PS/2 mouse device common for all mice
[ 1.756451] sdhci: Secure Digital Host Controller Interface driver
[ 1.756482] sdhci: Copyright(c) Pierre Ossman
[ 1.756896] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.759746] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.760049] hid: raw HID events driver (C) Jiri Kosina
[ 1.760225] usbcore: registered new interface driver usbhid
[ 1.760249] usbhid: USB HID core driver
[ 1.764855] Initializing XFRM netlink socket
[ 1.764917] NET: Registered PF_PACKET protocol family
[ 1.764999] Key type dns_resolver registered
[ 1.765494] Registering SWP/SWPB emulation handler
[ 1.766176] registered taskstats version 1
[ 1.766249] Loading compiled-in X.509 certificates
[ 1.767062] Key type .fscrypt registered
[ 1.767086] Key type fscrypt-provisioning registered
[ 1.778457] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.778926] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.779043] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 51, base_baud = 0) is a PL011 rev2
[ 1.786661] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.787004] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.787895] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.787926] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.815594] of_cfs_init
[ 1.815772] of_cfs_init: OK
[ 1.853867] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.854248] Waiting for root device PARTUUID=9d55f89b-02...
[ 1.896206] mmc1: new high speed SDIO card at address 0001
[ 1.953652] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 1.954435] mmcblk0: mmc0:59b4 SMI 14.8 GiB
[ 1.956741] mmcblk0: p1 p2
[ 1.957178] mmcblk0: mmc0:59b4 SMI 14.8 GiB
[ 1.980633] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.980669] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.033813] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.216381] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.216430] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.216457] usb 1-1: Product: USB2.0 Hub
[ 2.218406] hub 1-1:1.0: USB hub found
[ 2.218696] hub 1-1:1.0: 4 ports detected
[ 2.490300] EXT4-fs (mmcblk0p2): recovery complete
[ 2.498486] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.498574] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.500677] devtmpfs: mounted
[ 2.508703] Freeing unused kernel image (initmem) memory: 2048K
[ 2.509015] Run /sbin/init as init process
[ 2.509036] with arguments:
[ 2.509044] /sbin/init
[ 2.509053] with environment:
[ 2.509061] HOME=/
[ 2.509070] TERM=linux
[ 2.852825] systemd[1]: System time before build time, advancing clock.
[ 3.046392] NET: Registered PF_INET6 protocol family
[ 3.047743] Segment Routing with IPv6
[ 3.047794] In-situ OAM (IOAM) with IPv6
[ 3.110324] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 3.111120] systemd[1]: Detected architecture arm.
[ 3.118439] systemd[1]: Set hostname to .
[ 3.993028] systemd[1]: Queued start job for default target Multi-User System.
[ 4.046955] systemd[1]: Created slice system-getty.slice.
[ 4.048456] systemd[1]: Created slice system-modprobe.slice.
[ 4.049611] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.050585] systemd[1]: Created slice User and Session Slice.
[ 4.051232] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.051859] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.053073] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.053608] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.054286] systemd[1]: Reached target Paths.
[ 4.054749] systemd[1]: Reached target Slices.
[ 4.055185] systemd[1]: Reached target Swap.
[ 4.056369] systemd[1]: Listening on Syslog Socket.
[ 4.057262] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.057855] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.059006] systemd[1]: Listening on Journal Audit Socket.
[ 4.059887] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.060904] systemd[1]: Listening on Journal Socket.
[ 4.062839] systemd[1]: Listening on udev Control Socket.
[ 4.063720] systemd[1]: Listening on udev Kernel Socket.
[ 4.064846] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.069410] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.075251] systemd[1]: Mounting RPC Pipe File System...
[ 4.081428] systemd[1]: Mounting Kernel Debug File System...
[ 4.087999] systemd[1]: Mounting Kernel Trace File System...
[ 4.089404] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 4.098359] systemd[1]: Starting Restore / save the current clock...
[ 4.104815] systemd[1]: Starting Set the console keyboard layout...
[ 4.111457] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.118830] systemd[1]: Starting Load Kernel Module configfs...
[ 4.125803] systemd[1]: Starting Load Kernel Module drm...
[ 4.133767] systemd[1]: Starting Load Kernel Module fuse...
[ 4.148856] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.154713] systemd[1]: Starting File System Check on Root Device...
[ 4.166129] systemd[1]: Starting Journal Service...
[ 4.200864] systemd[1]: Starting Load Kernel Modules...
[ 4.214859] systemd[1]: Starting Coldplug All udev Devices...
[ 4.225781] fuse: init (API version 7.37)
[ 4.229679] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.230602] systemd[1]: Mounted RPC Pipe File System.
[ 4.233561] systemd[1]: Mounted Kernel Debug File System.
[ 4.235639] systemd[1]: Mounted Kernel Trace File System.
[ 4.240063] systemd[1]: Finished Restore / save the current clock.
[ 4.243113] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.245261] systemd[1]: modprobe@configfs.service: Succeeded.
[ 4.246669] systemd[1]: Finished Load Kernel Module configfs.
[ 4.248746] systemd[1]: modprobe@fuse.service: Succeeded.
[ 4.250142] systemd[1]: Finished Load Kernel Module fuse.
[ 4.257299] systemd[1]: Mounting FUSE Control File System...
[ 4.263359] systemd[1]: Mounting Kernel Configuration File System...
[ 4.269724] systemd[1]: Started File System Check Daemon to report status.
[ 4.281053] systemd[1]: Mounted FUSE Control File System.
[ 4.293731] systemd[1]: Mounted Kernel Configuration File System.
[ 4.368536] systemd[1]: modprobe@drm.service: Succeeded.
[ 4.369627] systemd[1]: Finished Load Kernel Module drm.
[ 12.493680] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 12.504348] systemd[1]: Finished Load Kernel Modules.
[ 12.615051] systemd[1]: Starting Apply Kernel Variables...
[ 12.617900] systemd[1]: Finished File System Check on Root Device.
[ 12.628003] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.704977] systemd[1]: Finished Apply Kernel Variables.
[ 12.776345] systemd[1]: Started Journal Service.
[ 12.789592] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 12.899698] systemd-journald[141]: Received client request to flush runtime journal.
[ 12.967114] systemd-journald[141]: File /var/log/journal/b394751f52b749b9b2bde05ea468aa15/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 14.262087] mc: Linux media interface: v0.10
[ 14.316672] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.318623] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 14.318646] [vc_sm_connected_init]: start
[ 14.327208] [vc_sm_connected_init]: installed successfully
[ 14.453594] videodev: Linux video capture interface: v2.00
[ 14.590356] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.593316] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.612168] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.620129] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.628100] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.643949] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 14.644602] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 14.645165] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 14.645607] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 14.645639] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 14.645659] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 14.645676] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 14.645691] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 14.653450] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 14.654246] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 14.654741] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 14.655118] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 14.655143] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 14.655163] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 14.655179] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 14.655205] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 14.655436] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 14.665405] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 14.671171] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.707759] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.760429] rpivid feb10000.codec: Device registered as /dev/video19
[ 14.826363] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 14.827024] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 15.027341] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 15.027387] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 15.039096] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 15.039144] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 15.074558] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 15.074604] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 15.088472] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 15.088529] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 15.100517] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 15.100558] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 15.334576] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 15.385701] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 15.399838] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 15.400824] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 15.547876] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 15.590320] Registered IR keymap rc-cec
[ 15.590531] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 15.590754] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 15.604460] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 15.608348] Registered IR keymap rc-cec
[ 15.608573] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 15.608846] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[ 15.618939] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 15.619593] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 15.620105] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 15.620571] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 15.621139] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 15.621502] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 15.621985] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 15.623596] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 15.632490] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 15.633172] usbcore: registered new interface driver brcmfmac
[ 15.636432] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 15.637122] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 15.642910] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 15.908004] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 16.332210] uart-pl011 fe201000.serial: no DMA platform data
[ 16.560238] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 16.624127] 8021q: 802.1Q VLAN Support v1.8
[ 16.996761] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 17.399864] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 17.401546] bcmgenet fd580000.ethernet eth0: Link is Down
[ 19.738171] systemd-journald[141]: File /var/log/journal/b394751f52b749b9b2bde05ea468aa15/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 22.607660] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 23.498380] Bluetooth: Core ver 2.22
[ 23.498463] NET: Registered PF_BLUETOOTH protocol family
[ 23.498470] Bluetooth: HCI device and connection manager initialized
[ 23.498489] Bluetooth: HCI socket layer initialized
[ 23.498498] Bluetooth: L2CAP socket layer initialized
[ 23.498514] Bluetooth: SCO socket layer initialized
[ 23.510392] Bluetooth: HCI UART driver ver 2.3
[ 23.510408] Bluetooth: HCI UART protocol H4 registered
[ 23.510475] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 23.510625] Bluetooth: HCI UART protocol Broadcom registered
[ 23.835986] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.835997] Bluetooth: BNEP filters: protocol multicast
[ 23.836007] Bluetooth: BNEP socket layer initialized
[ 23.839689] Bluetooth: MGMT ver 1.22
[ 23.852272] NET: Registered PF_ALG protocol family
[ 23.866880] cryptd: max_cpu_qlen set to 1000
[ 24.239113] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
