Service will not start
Today I download octoprint, create SD card with octoprint and upload it to rapsberry pi.
after it didn't work I
try to reinstall it and update it and it is the same
try to find octoprint.log and doesn't exist.
here is web log
The OctoPrint server is currently not running
If you just started up your Raspberry Pi, please wait a couple of seconds, then try to refresh this page.
If the issue persists, please log into your Raspberry Pi via SSH and check the following:
- Verify that the process is running:
ps -ef | grep -i octoprint | grep -i pythonshould show a python process:
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1441 1 6 11:12 ? 00:00:15 /home/pi/oprint/bin/python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
- If it isn't, the question is why. Take a look into
~/.octoprint/logs/octoprint.log, there might be an error logged in there that helps to determine what's wrong. - You might also want to try if you can restart the server (if no obvious error is visible):
sudo service octoprint restart.
If all that doesn't help to trouble shoot the issue, you can seek support on the OctoPrint Community Forum. Please provide your OctoPi and OctoPrint versions as well as your octoprint.log and explain what you already tried and observed as detailed as possible.
No, it doesn't work. This is the only config.yaml
/home/daman/.octoprint/config.yaml
I have found these folders and files and it exist.
Nov 13 17:42:29 pi systemd[3607]: octoprint.service: Failed to execute /home/daman/oprint/bin/octoprint: No such file or directory
Nov 13 17:42:29 pi systemd[3607]: octoprint.service: Failed at step EXEC spawning /home/daman/oprint/bin/octoprint: No such file or directory
