Pulled logs, restarted
See above
OctoPrint version 1.7.2, OctoPi version 0.18.0, Ender 3, Marlin, Chrome, W10, ... as much data as possible
2022-03-30 19:05:00,980 - octoprint.server - INFO - OctoPrint 1.7.2
2022-03-30 19:05:00,986 - octoprint.plugin.core - INFO - 27 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Bed Leveling Wizard (0.2.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_bedlevelingwizard
| Bed Visualizer (1.1.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_bedlevelvisualizer
| BLTouch Plugin (0.3.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_BLTouch
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| DisplayLayerProgress Plugin (1.27.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_DisplayLayerProgress
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Event Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/eventmanager
| File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2021.10.11) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Octolapse (0.4.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse
| Pi Support Plugin (2021.10.28) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| PrintTimeGenius Plugin (2.2.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius
| Simple Emergency Stop (1.0.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_simpleemergencystop
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Tab Order (0.5.12) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_taborder
| Themeify (1.2.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_themeify
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2022-03-30 19:05:01,005 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 915718144
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2022-03-30 21:17:26,515 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: offline
2022-03-30 21:17:26,516 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is not working
2022-03-30 21:17:26,516 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
2022-03-30 21:17:27,796 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2022-03-30 21:17:28,414 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2022-03-30 21:17:29,711 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 1291, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 68, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 238, in load_module
return load_package(name, filename)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 212, in load_package
return _load(spec)
File "<frozen importlib._bootstrap>", line 696, in _load
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements/__init__.py", line 26, in <module>
from octoprint.server.util.flask import (
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/__init__.py", line 49, in <module>
from octoprint.server import util
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/util/__init__.py", line 24, in <module>
from . import flask, sockjs, tornado, watchdog # noqa: F401
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/util/flask.py", line 23, in <module>
import tornado.web
File "/home/pi/oprint/lib/python3.7/site-packages/tornado/web.py", line 86, in <module>
from tornado import gen
File "/home/pi/oprint/lib/python3.7/site-packages/tornado/gen.py", line 89, in <module>
from tornado.ioloop import IOLoop
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 857, in get_code
File "<frozen importlib._bootstrap_external>", line 525, in _compile_bytecode
ValueError: bad marshal data (unknown type code)
2022-03-30 21:17:29,778 - octoprint.plugin.core - ERROR - Error loading plugin logging
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging/__init__.py", line 19, in <module>
from octoprint.server import NO_CONTENT
import tornado.web
2022-03-30 21:17:29,896 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys/__init__.py", line 16, in <module>
from octoprint.server import NO_CONTENT, admin_permission, current_user
import tornado.web
2022-03-30 21:17:30,244 - octoprint.plugin.core - ERROR - Error loading plugin errortracking
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking/__init__.py", line 12, in <module>
import tornado.websocket
File "/home/pi/oprint/lib/python3.7/site-packages/tornado/websocket.py", line 27, in <module>
import tornado.web
2022-03-30 21:17:30,477 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 33, in <module>
from octoprint.server import safe_mode
import tornado.web
2022-03-30 21:17:30,623 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 31, in <module>
from octoprint.server import BRANCH, NO_CONTENT, REVISION, VERSION
import tornado.web
2022-03-30 21:17:30,825 - octoprint.plugin.core - ERROR - Error loading plugin backup
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup/__init__.py", line 11, in <module>
import tornado.web
2022-03-30 21:17:31,502 - octoprint.plugin.core - ERROR - Error loading plugin octolapse
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/__init__.py", line 37, in <module>
from octoprint.server import util, app
import tornado.web
2022-03-30 21:17:31,848 - octoprint.plugin.core - INFO - Found 19 plugin(s) providing 19 mixin implementations, 37 hook handlers
2022-03-30 21:17:31,866 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/__init__.py", line 965, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/decorators.py", line 21, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 329, in serve_command
overlays=overlays,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 146, in run_server
from octoprint.server import CannotStartServerException, Server
import tornado.web
