After initiating the 1.4.0 update via the webpage interface, I am unable to connect to the server. Entering the Raspberry Pi's IP address in a browser shows an error page stating that "The OctoPrint server is not currently running."
Per the error page, I have verified that the process is not running (ps -ef | grep -i octoprint | grep -i python), and attempted to restart the service (sudo service octoprint restart), with no luck (no error, but service doesn't appear to start). Looking at the log suggests that something went wrong while it was updating. I have also rerun the pip install commands (per How can I update the OctoPrint installation on my OctoPi image?), which returns the following:
Looking in indexes: [link redacted due to posting restrictions]
Requirement already up-to-date: octoprint in ./oprint/lib/python2.7/site-packages (1.4.0)
And has no impact on the service restart command, seemingly.
2020-03-05 10:53:04,426 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-05 10:53:04,431 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-03-05 10:53:04,432 - octoprint.server - INFO - OctoPrint 1.3.12
2020-03-05 10:53:04,439 - octoprint.plugin.core - INFO - 21 plugin(s) registered with the system:
| GcodeEditor (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GcodeEditor
| HeaterTimeout (0.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_HeaterTimeout
| LED Strip Control (0.3.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_LEDStripControl
| M73 Progress Plugin (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_m73progress
| Multi Colors (1.0.16) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_multi_colors
| Progress Title (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_progress_title
2020-03-05 10:53:04,466 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2020-03-05 10:53:04,467 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-03-05 10:53:07,021 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 421224}
2020-03-05 11:08:04,428 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-05 11:08:07,716 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 422124}
2020-03-05 11:23:04,431 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-05 11:23:06,966 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 423024}
2020-03-05 11:23:10,470 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2020-03-05 11:23:10,472 - octoprint.filemanager.analysis - INFO - Starting analysis of local:LM2SE05MM_order_2041_12f7a1ad.gcode
2020-03-05 11:23:10,477 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=18000 --speed-y=18000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/LM2SE05MM_order_2041_12f7a1ad.gcode
2020-03-05 11:23:14,937 - octoprint.printer.standard.job - INFO - Print job paused - origin: local, path: LM2SE05MM_order_2041_12f7a1ad.gcode, owner: _api, user: lulzbot
2020-03-05 11:23:14,947 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2020-03-05 11:23:22,763 - octoprint.filemanager.analysis - INFO - Analysis of entry local:LM2SE05MM_order_2041_12f7a1ad.gcode finished, needed 12.29s
2020-03-05 11:27:51,704 - octoprint.util.comm - INFO - Changing monitoring state from "Paused" to "Resuming"
2020-03-05 11:27:51,712 - octoprint.printer.standard.job - INFO - Print job resumed - origin: local, path: LM2SE05MM_order_2041_12f7a1ad.gcode, owner: _api, user: None
2020-03-05 11:27:51,718 - octoprint.util.comm - INFO - Changing monitoring state from "Resuming" to "Printing"
2020-03-05 11:27:51,732 - octoprint.util.comm - INFO - Pausing print job due to command M0
2020-03-05 11:27:51,735 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2020-03-05 11:27:51,738 - octoprint.util.comm - INFO - Not sending M0 to printer, it's configured as a blocked command
2020-03-05 11:27:51,818 - octoprint.printer.standard.job - INFO - Print job paused - origin: local, path: LM2SE05MM_order_2041_12f7a1ad.gcode, owner: _api, user: None
2020-03-05 11:27:51,829 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2020-03-05 11:28:42,681 - octoprint.util.comm - INFO - Changing monitoring state from "Paused" to "Resuming"
2020-03-05 11:28:42,709 - octoprint.printer.standard.job - INFO - Print job resumed - origin: local, path: LM2SE05MM_order_2041_12f7a1ad.gcode, owner: _api, user: lulzbot
2020-03-05 11:28:42,730 - octoprint.util.comm - INFO - Changing monitoring state from "Resuming" to "Printing"
2020-03-05 11:38:04,432 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-05 11:38:08,120 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 423924}
2020-03-05 11:48:47,758 - octoprint.util.comm - INFO - Finished in 4092.566 s.
2020-03-05 11:48:47,760 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2020-03-05 11:48:47,779 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: LM2SE05MM_order_2041_12f7a1ad.gcode, owner: _api
2020-03-05 11:48:47,840 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2020-03-05 11:48:48,992 - octoprint.plugins.tracking - INFO - Sent tracking event print_done, payload: {'origin': 'local', 'throttled_mask': 327680, 'elapsed': 3760, 'file': 'c38dcb116070cbc69cc932e293aa2692ee19cf14', 'throttled_now': False, 'throttled_past': True}
2020-03-05 11:53:04,434 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-05 11:53:07,443 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 424824}
2020-03-05 11:56:13,221 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.4.0...
OctoPrint version: 1.4.0?
OctoPi version: 0.16.0
Printer: Lulzbot Mini 2
Firmware: Marlin 2.0.0
Operating system: Windows 10
Browser: Chrome
