Octoprint server not working
ps -ef | grep -i octoprint | grep -i python (nothing :\ )
I tried restart with sudo octoprint restart service but didn't work. Nothing happened
Octoprint 1.3.9
Anet A8
Marlin 1.1.8 octoprint.log (38.2 KB)
From the log you posted:
2018-11-16 17:14:35,319 - octoprint.plugins.telegram.listener - ERROR - Setting status: Got an exception while trying to connect to telegram API: HTTPSConnectio nPool(host='api.telegram.org', port=443): Max retries exceeded with url: /bot575 108161:AAHa7bmYl03pNpm0FlYIJYY9MAcwoJrUga8/getUpdates?timeout=30&offset=1 (Cause d by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0 x6c948d10>: Failed to establish a new connection: [Errno -3] Temporary failure i n name resolution',)). Waiting 2 minutes before trying again.
2018-11-16 22:50:49,460 - octoprint.timelapse - ERROR - Could not capture image /home/pi/.octoprint/timelapse/tmp/Water_Tank_Villa_Pot_20181116051737-6317.jpg f rom http://127.0.0.1:8080/?action=snapshot
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/timelapse.py ", line 596, in _perform_capture
f.flush()
And then you accidentally pasted the logs into the terminal, so the output goes haywire. Try starting in safe mode; I think the second error is less important.
