Server offline after print homes
My Ender 3 Pro is setup with Octopi running Klipper firmware. When I try to print, the printer will home and then immediately I get a message that the server is offline.
I restarted Octopi using putty.
I get this message:
** Verify that the process is running: ps -ef | grep -i octoprint | grep -i python should show a python process:*
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1441 1 6 11:12 ? 00:00:15 /home/pi/oprint/bin/python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
** If it isn't, the question is why. Take a look into ~/.octoprint/logs/octoprint.log, there might be an error logged in there that helps to determine what's wrong.*
** You might also want to try if you can restart the server (if no obvious error is visible): sudo service octoprint restart."*
I verified the server is running, mine says python3 instead of python.
I did run in safe mode.
The print did work in safe mode. So does that mean a plugin is the issue. If so, how to determine which one?
octoprint-systeminfo-20230726140905.zip (3.3 MB)
I had to delete the haproxy.log file in order to get the file size under 4mb. Not sure if that is a problem.
OctoPrint version : 1.9.2
OctoPi version : 0.18.0
Klipper firmware
Windows10 and Chrome
Ender3 pro with stock control board
I had not used the printer is a while and just updated everything. It had run fine prior to that. Thanks for all the support.
