I want to limit the speed and acceleration on my (much modified) Ender 3. When I specify the parameters in Prusa Slicer, that's fine, but the genrated Gcode looks like this:
; generated by PrusaSlicer 2.6.0+MacOS-arm64 on 2023-07-04 at 20:14:48 UTC
; external perimeters extrusion width = 0.42mm
; perimeters extrusion width = 0.44mm
; infill extrusion width = 0.44mm
; solid infill extrusion width = 0.44mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.42mm
M201 X500 Y500 Z100 E5000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z10 E60 ; sets maximum feedrates, mm / sec
M204 S500 T1000 ; sets acceleration (S) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E5.00 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M190 S60 ; set bed temperature and wait for it to be reached
M104 S205 ; set temperature
Terminal gives error messages that the M20x commands are invalid.
Looked in printer.cfg but could not find anything. I found some references on the forum about config.yaml but it looks like they are only referencing those commands, not enabling them.
No.
octoprint-systeminfo-20230704215249.zip (16.0 KB)
OctoPrint 1.9.1
OctoPi Version 1.0.0, running on Raspberry Pi 4 Model B Rev 1.5
Printer is modified Creality 3 (added 2nd Z-axis motor, changed to Ender direct-feed extruder)
Firmware 4.2.7
Web browser is Safari
MacOS 14.0
TIA for help
Walt
