Trying to get a second camera working on my octopi
Followed this Setting up multiple webcams in OctoPi the right way and tried looking at some of the solutions in there but couldnt get the 8081 port to send an image
no
This is the webcamd.log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 640x480 -f 10 -d /dev/v41/by-id/usb-GenesysLogic_Technology_Co.__Ltd._USB2.0_UVC_PC_Camera-video-index0
raspi options: -fps 10
http options: -w ./www-octopi -n
Explicitly USB device:
cfg_file: /boot/octopi.conf.d/webcam2.txt
camera: usb
usb options: -r 640x480 -f 10 -d /dev/v41/by-id/usb-SHENZHEN_AONI_ELECTRONIC_CO.__LTD_Full_HD_webcam_AN202011030002-video-index0
http options: -w ./www-octopi -p 8081
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video2
/dev/video3
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Jul 18 22:51:04 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 640x480 -f 10 -d /dev/v41/by-id/usb-GenesysLogic_Technology_Co.__Ltd._USB2.0_UVC_PC_Camera-video-index0 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
Unable to set format: 1196444237 res: 640x480
i: init_VideoIn failed
Goodbye...
Anything im missing information wise please let me know
