Hi guys,
I am having some issues with my nginx setup.
I run with https and a letscrypt certificate.
The setup actually works, mostly, but if I want to download a logfile, it dumps me at a 404.
I assume it's the path, that some how messes up, when I hit /downloads/logs/octoprint.log (example).
I have the following nginx setup:
#octoprint
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream "octoprint" {
server 192.168.1.143:80;
upstream "octoprintcam" {
server 192.168.1.143:8080;
# Octoprint
location /octoprint/ {
proxy_pass http://octoprint;
proxy_set_header Host $host:$server_port;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Scheme $scheme;
proxy_set_header X-Script-Name /octoprint;
proxy_http_version 1.1;
location ~ /octoprint/(?<pathinfo>(downloads|static|api|plugin).*) {
proxy_pass http://octoprint/$pathinfo;
proxy_set_header Host $host;
location /octoprint/webcam/ {
proxy_pass http://octoprintcam/;
location /octoprint/sockjs {
proxy_pass http://octoprint/sockjs; # NO trailing slash here!
Now, I would assume my pathinfo location would grab the example url and pass it to the correct location but alas, it does not work
Any ideas what I'm doing wrong here?
