Settings not opening anymore
When clicking on the wrench, the settings don't open anymore
Restarted the rasperry
Tried another browser (Edge, Chrome)
Tried on another computer (Edge, Chrome)
Emptied browser caches
Checked if popups are allowed, even though it's a modal
Started in safe mode
Ask for advice here
Octoprint: 1.3.9
Octopi: 0.15.1
Please startup OctoPrint in Safe mode and see if that solves the problem.
If it does, then one of the installed plugins is possibly getting in the way and then we can further troubleshoot this.
Ok, I'm sorry, found out the problem, "Stop at height" plugin was causing the problem. Sorry about that
Have you reported this to the plugin creator?
Yes, but got no answer
The question is, if this plugin still exists. I can't find it in the repository.
I have the same issue, how I can remove the plugin if I can not access to the "settings" menu ?
Start in safe mode. Then you should be able to remove it.
Yes, thank you for the answer. I fixed it.
