I'm trying to install the "OctoPrint-WebcamStreamer" plugin and set it up to stream on Twitch. That part seems to be configured but I'm struggling with the Docker part of the installation and getting two different errors.
Within OctoPrint i get the following: "WebcamStreamer Error 404 Client Error: Not Found ("pull access denied for adilinden/rpi-ffmpeg, repository does not exist or may require 'docker login': denied: requested access to the resource is denied")"
While in SSH when trying to pull the docker image I get the following "pi@octopi:~ $ docker pull adilinden/rpi-stream:latest Error response from daemon: pull access denied for adilinden/rpi-stream, repository does not exist or may require 'docker login': denied: requested access to the resource is denied"
I've tried to reinstall the plugin by reinstalling the Docker as per the instructions via SSH but getting the following error from that
others seem to have the same problem and @adilinden said a month ago
I currently do not have a working 3D printer due to ongoing renovations. Means I am in no position to actually test anything. If there are willing participants that would like to continue development, I would welcome additional maintainers.
Seem to be clear with that one but still having some issues (which i assume is just me being stupid).
Run the docker and installation and getting the following message during the test process.
