- I'm not sure how to assign individual ports to each printer. How to correctly create the symlinks in OSX?
- How do I setup a second instance of OctoPrint. Where do I find the basedir and port for the config script and how to change OctoPrint for OctoPrint2 in the init script.
- I tried " ioreg -lp IOUSB " as the OSX equivalent to "udevadm info -q all -n /dev/ttyUSB0 --attribute-walk" to get the device info, but I'm not sure what of all the output should I compare or use. Do the 2 printers need to be plugged at this time?
- I duplicated the OctoPrint folder in the same directory as the original one and named it OctoPrint2, but I'm not sure what should I modify in the scrips
I'm using this guide for a RasPi trying to figure out how to do it in OSX. https://jandra.wordpress.com/2019/10/07/octoprint-running-multiple-instances-webcam/
Complete Logs
This is the info I get from the ports (from the ioreg command)
"sessionID" = 1292253490
| "AAPL,standard-port-current-in-sleep" = 500
| "iManufacturer" = 0
| "bNumConfigurations" = 1
| "idProduct" = 32776
| "bcdDevice" = 5
| "Bus Power Available" = 250
| "bMaxPacketSize0" = 64
| "iProduct" = 0
| "iSerialNumber" = 0
| "USB Address" = 2
| "bDeviceClass" = 9
| "IOUserClientClass" = "IOUSBDeviceUserClientV2"
| "bDeviceSubClass" = 0
| "locationID" = 437256192
| "bcdUSB" = 512
| "Ports" = 6
| "PortNum" = 1
| "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBFam$
| "bDeviceProtocol" = 1
| "Device Speed" = 2
| "idVendor" = 32903
| "Requested Power" = 0
| "IOGeneralInterest" = "IOCommand is not serializable"
| "Low Power Displayed" = No
I'm using a hackintosh with OSX 10.10.5. I think I downloaded OctoPrintV3 (thats what the readme and licence file say), but where can I verify this?
