In the Files section of the sidebar, I'd like to add whitespace (a gap) between each file.
Here's what it looks like, and then also what I'm trying to do
I have Themeify installed, and I created a custom style to do just this. The style has
selector: .entry.machinecode
CSS rule: margin-bottom
value: 40px
... and I've found that if I go into settings, add/or change this style, and then click Save, the custom CSS rule is applied and looks as desired. However, if the sidebar is updated (eg, when a new file is added) or when the page is refreshed, the custom CSS rule is not applied.
At this point, you might be saying that this is a Themefy issue, and go post this in the Plugins category. However, I don't think this is a Themeify issue because:
- the other custom CSS styles I've created (via Themeify) aren't having any issues, just this one in the dashboard
- when inspecting the DOM that's generated, I see markup that uses $root, like this:
attr: { id: $root.getEntryId($data) }, template: { name: $root.templateFor($data), data: $data }, css: $data.type
I haven't looked at the git repro, but I'm guessing OctoPrint is using Knockout(?) If so, I suspect it (or whatever framework OctoPrint is using) is somehow ignoring this CSS rule I've created.
My ask here is:
- could one of the devs look into this? Is this a dashboard issue, or is this a Themeify issuse? And if not a Themeify issue, can a fix be issued?
- could extra bottom margin be added to the dashboard file items? This way, I wouldn't need to define a custom rule in Themeify.
I performed a number of A-B tests to troubleshoot this. I've narrowed down the issue, and I think I've described the exact (and minimum) steps needed to repro the issue.
Complete Logs
no logs
Other Information
Mac, using the latest version of Chrome
