Trying to install and use Signal Notifier as this looks like a good replacement for the SMS Notifier I had been using with my free Twilio trial that has ended.
The issue seems to be getting signal-cli pre-requisites installed, specifically JAVA JRE appropriate version.
Not a Linux guy but I have some experience...
Installed JRE using app-get install default-jre which got me JRE 8.
Tried to register using signal-cli and it said I needed Java 11 (not in those words... more along the lines of "has been compiled by a more recent version of the Java Runtime (class file version 55.0),
this version of the Java Runtime only recognizes class file versions up to 52.0"
Which I interpretted to mean compiled with version 11 and you have 8...
Tried to find and install 11 and ended up with openjdk 11 and another version 11 from bell-sw
With those installed I could actually run some of signal-cli and did manage to register and verify my number. But sending a test message produced a java error.
I did apt-get update and apt-get upgrade so all were up to date...
NA
Complete Logs
Here is my SSH output from signal-cli with one of the version 11 JREs installed.
pi@octopi:/opt/jdk $ signal-cli -u +14165551212 register
OpenJDK Client VM warning: You have loaded library /tmp/resource18416904156527056177.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c ', or link it with '-z noexecstack'.
WARNING: Support for new group V2 is disabled, because the required native library dependency is missing: libzkgroup
pi@octopi:/opt/jdk $ signal-cli -u +14165551212 verify 356-202
OpenJDK Client VM warning: You have loaded library /tmp/resource6160890921011969700.so which might have disabled stack guard. The VM will try to fix the stack guard now.
pi@octopi:/opt/jdk $ java -version
openjdk version "11.0.9.1" 2020-11-04 LTS
OpenJDK Runtime Environment (build 11.0.9.1+1-LTS)
OpenJDK 32-Bit Server VM (build 11.0.9.1+1-LTS, mixed mode)
pi@octopi:/opt/jdk $ signal-cli -u +14165551212 send -m "Helo World" +14165551212
OpenJDK 32-Bit Server VM warning: You have loaded library /tmp/resource2620184490050639422.so which might have disabled stack guard. The VM will try to fix the stack guard now.
Exception in thread "main" java.lang.NoClassDefFoundError: Could not initialize class org.signal.zkgroup.internal.Native
at org.signal.zkgroup.profiles.ProfileKey.getProfileKeyVersion(ProfileKey.java:47)
at org.whispersystems.signalservice.api.SignalServiceMessagePipe.getProfile(SignalServiceMessagePipe.java:238)
at org.asamk.signal.manager.helper.ProfileHelper.getPipeRetrievalFuture(ProfileHelper.java:98)
at org.asamk.signal.manager.helper.ProfileHelper.lambda$retrieveProfile$5(ProfileHelper.java:79)
at org.whispersystems.signalservice.internal.util.concurrent.CascadingFuture.doNext(CascadingFuture.java:69)
at org.whispersystems.signalservice.internal.util.concurrent.CascadingFuture.(CascadingFuture.java:33)
at org.asamk.signal.manager.helper.ProfileHelper.retrieveProfile(ProfileHelper.java:79)
at org.asamk.signal.manager.helper.ProfileHelper.retrieveProfileSync(ProfileHelper.java:49)
at org.asamk.signal.manager.Manager.getEncryptedRecipientProfile(Manager.java:572)
at org.asamk.signal.manager.Manager.retrieveRecipientProfile(Manager.java:635)
at org.asamk.signal.manager.Manager.getRecipientProfile(Manager.java:591)
at org.asamk.signal.manager.helper.UnidentifiedAccessHelper.getTargetUnidentifiedAccessKey(UnidentifiedAccessHelper.java:49)
at org.asamk.signal.manager.helper.UnidentifiedAccessHelper.getAccessFor(UnidentifiedAccessHelper.java:83)
at org.asamk.signal.manager.Manager.sendSelfMessage(Manager.java:1456)
at org.asamk.signal.manager.Manager.sendMessage(Manager.java:1434)
at org.asamk.signal.manager.Manager.sendMessage(Manager.java:1026)
at org.asamk.signal.dbus.DbusSignalImpl.sendMessage(DbusSignalImpl.java:68)
at org.asamk.signal.commands.SendCommand.handleCommand(SendCommand.java:101)
at org.asamk.signal.Main.handleCommands(Main.java:192)
at org.asamk.signal.Main.handleCommands(Main.java:141)
at org.asamk.signal.Main.main(Main.java:65)
p
Octoprint running on
pi@octopi:/opt/jdk $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
