If I power up the printer and the Raspberry Pi the same time (or the printer first, the RPi next) then I have serial connection issues in Octorprint. I press the connect button, and check the terminal tab, then I see strange broken messages from the printer, like:
Send: N0 M110 N0*125
Recv: cho:Unknown command: "� "
Sometimes it tries to send more messages, but the response arrives still wrong and delayed for tens of seconds. Sooner or later the RPi gives up:
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793
Please see https://faq.octoprint.org/serialerror for possible reasons of this.
Until this time, it was discussed several times here, but my problem is different:
If I unplug then replug the USB cable between the the printer and the RPi, and then try to connect again, then everything works flawlessly! If I power on the Raspberry first, wait for Octoprint to start, then turn on the printer, then also everyting works perfectly. No issue at all.
But I want to power everyting up at the same time with a smart wall plug, so I DO need everyting to work this way also.
- Changed to factory 5.1V PSU for RPi
- Disconnected everyting else from the RPi
- Changed the baud rate in Marlin from 250000 to 115000
- Insulated the 5V pin of the USB plug
- Tried other USB cables: shieleded, and one with a ferrite ring
- Disconnected TFT35 smart display from the printer
- Disabled Bluetooth in config.txt: dtoverlay=pi3-disable-bt
OctoPrint version: 1.3.12
OctoPi version: 0.17.0
Raspberry Pi 3 B+
Ender3 with SKR Mini E3 V1.2 board
Marlin version 2.0.3
Logs
dmesg via putty. Simultaneous startup:
(When fails)
[ 3.152120] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL + XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr id)
[ 3.182843] systemd[1]: Detected architecture arm.
[ 3.212358] systemd[1]: Set hostname to <octopi>.
[ 3.229654] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argumen t
[ 3.351900] usb 1-1.1.3: new full-speed USB device number 4 using dwc_otg
[ 3.422030] uart-pl011 3f201000.serial: no DMA platform data
[ 3.515086] usb 1-1.1.3: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[ 3.529217] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumb er=0
[ 3.542280] usb 1-1.1.3: Product: Maple
[ 3.548812] usb 1-1.1.3: Manufacturer: LeafLabs
[ 3.657481] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not sup port BPF/cgroup based firewalling.
[ 3.683286] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni ng is only shown for the first loaded unit using IP firewalling.)
[ 3.851812] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[ 3.992264] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 4.006689] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumb er=0
[ 4.161573] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.183515] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.201441] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.214905] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.225434] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.238609] systemd[1]: Listening on udev Kernel Socket.
[ 4.250869] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.285484] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No Exte rnal EEPROM. Setting MAC Speed
[ 4.286612] libphy: lan78xx-mdiobus: probed
[ 4.352170] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.041965] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.158619] systemd-journald[108]: Received request to flush runtime journal from PID 1
[ 5.982010] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 5.984501] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.984516] [vc_sm_connected_init]: start
[ 5.986950] [vc_sm_connected_init]: installed successfully
[ 6.003406] media: Linux media interface: v0.10
[ 6.050031] videodev: Linux video capture interface: v2.00
[ 6.084466] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 6.084470] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 6.111932] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned.
[ 6.127167] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.154913] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.163701] bcm2835_audio soc:audio: card created with 8 channels
[ 6.336726] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase
[ 6.339050] cdc_acm 1-1.1.3:1.0: ttyACM0: USB ACM device
[ 6.340056] usbcore: registered new interface driver cdc_acm
[ 6.340067] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 6.436409] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.492045] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.504062] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6
[ 6.504978] usbcore: registered new interface driver brcmfmac
[ 6.743401] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.743475] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.746833] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.746903] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.750641] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.750707] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.766756] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6
[ 6.822766] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 6.877611] random: crng init done
[ 6.877628] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.517446] 8021q: 802.1Q VLAN Support v1.8
[ 8.673364] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:1 02396k SSFS
[ 8.898282] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.898303] brcmfmac: power management disabled
[ 9.158674] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.158693] 8021q: adding VLAN 0 to HW filter on device eth0
[ 20.920468] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Here I unplugged and plugged back the USB cable...
[ 297.534306] usb 1-1.1.3: USB disconnect, device number 4
[ 297.534463] cdc_acm 1-1.1.3:1.0: failed to set dtr/rts
[ 302.434768] usb 1-1.1.3: new full-speed USB device number 6 using dwc_otg
[ 302.567925] usb 1-1.1.3: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[ 302.567934] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumb er=0
[ 302.567938] usb 1-1.1.3: Product: Maple
[ 302.567942] usb 1-1.1.3: Manufacturer: LeafLabs
[ 302.568573] cdc_acm 1-1.1.3:1.0: ttyACM1: USB ACM device
dmesg via putty. Startup the Pi, wait Octoprint to run, then turn on the printer:
(When there is no problem)
[ 3.152493] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.183267] systemd[1]: Detected architecture arm.
[ 3.212935] systemd[1]: Set hostname to <octopi>.
[ 3.230256] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 3.383365] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 3.405846] uart-pl011 3f201000.serial: no DMA platform data
[ 3.598812] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.624482] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.821801] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
[ 3.952251] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 3.966719] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.110759] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.135576] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.145760] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.160105] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.170421] systemd[1]: Listening on udev Kernel Socket.
[ 4.184069] systemd[1]: Listening on Journal Socket.
[ 4.213830] systemd[1]: Starting Load Kernel Modules...
[ 4.254694] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 4.271931] libphy: lan78xx-mdiobus: probed
[ 4.301721] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.073042] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.191286] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 5.999732] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.002470] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.002485] [vc_sm_connected_init]: start
[ 6.008530] [vc_sm_connected_init]: installed successfully
[ 6.034651] media: Linux media interface: v0.10
[ 6.089803] videodev: Linux video capture interface: v2.00
[ 6.164476] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.169459] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.192133] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.277335] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.281664] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.297757] bcm2835_audio soc:audio: card created with 8 channels
[ 6.311328] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.444572] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.527755] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.537581] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.538436] usbcore: registered new interface driver brcmfmac
[ 6.763491] random: crng init done
[ 6.763503] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.765558] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.797811] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 6.823226] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.823275] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.826860] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.826898] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.830824] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.830860] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.540562] 8021q: 802.1Q VLAN Support v1.8
[ 8.747980] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.935519] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.935836] brcmfmac: power management disabled
[ 9.230236] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.230246] 8021q: adding VLAN 0 to HW filter on device eth0
[ 14.938759] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 71.341797] usb 1-1.1.3: new full-speed USB device number 5 using dwc_otg
[ 71.474934] usb 1-1.1.3: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[ 71.474947] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 71.474956] usb 1-1.1.3: Product: Maple
[ 71.474966] usb 1-1.1.3: Manufacturer: LeafLabs
[ 71.529652] cdc_acm 1-1.1.3:1.0: ttyACM0: USB ACM device
[ 71.530560] usbcore: registered new interface driver cdc_acm
[ 71.530569] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Serial.log Simultaneous startup:
(When fails):
2020-02-15 14:03:53,390 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-02-15 14:03:53,412 - Serial port list: ['/dev/ttyACM0']
2020-02-15 14:03:53,413 - Connecting to: /dev/ttyACM0
2020-02-15 14:03:53,416 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-02-15 14:03:53,420 - Connected to: Serial<id=0x6987b890, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-02-15 14:03:53,420 - Starting baud rate detection...
2020-02-15 14:03:53,421 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-02-15 14:03:54,429 - Trying baudrate: 115200
2020-02-15 14:03:54,445 - Send: N0 M110 N0*125
2020-02-15 14:03:54,448 - Recv: cho:Unknown command: "� "
2020-02-15 14:03:54,451 - Recv: ok
2020-02-15 14:03:54,456 - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-02-15 14:03:54,469 - Send: N0 M110 N0*125
2020-02-15 14:03:54,532 - Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793
2020-02-15 14:03:54,536 - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2020-02-15 14:03:54,541 - Changing monitoring state from "Operational" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
2020-02-15 14:03:54,699 - Connection closed, closing down monitor
Now I unplugged then replugged USB cable
2020-02-15 14:08:32,283 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-02-15 14:08:32,353 - Serial port list: ['/dev/ttyACM1']
2020-02-15 14:08:32,353 - Connecting to: /dev/ttyACM1
2020-02-15 14:08:32,359 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-02-15 14:08:32,364 - Connected to: Serial<id=0x6987b070, open=True>(port='/dev/ttyACM1', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-02-15 14:08:32,365 - Starting baud rate detection...
2020-02-15 14:08:32,367 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-02-15 14:08:33,374 - Trying baudrate: 115200
2020-02-15 14:08:33,382 - Send: N0 M110 N0*125
2020-02-15 14:08:33,385 - Recv: ok
2020-02-15 14:08:33,389 - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-02-15 14:08:33,397 - Send: N0 M110 N0*125
2020-02-15 14:08:33,403 - Recv: ok
2020-02-15 14:08:33,406 - Send: N1 M115*39
2020-02-15 14:08:33,409 - Recv: FIRMWARE_NAME:Marlin 2.0.3 (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-02-15 14:08:33,423 - Recv: Cap:SERIAL_XON_XOFF:0
2020-02-15 14:08:33,436 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-02-15 14:08:33,438 - Recv: Cap:EEPROM:
2020-02-15 14:08:33,440 - Recv: Cap:SOFTWARE_POWER:0
2020-02-15 14:08:33,442 - Recv: Cap:TOGGLE_LIGHTS:0
2020-02-15 14:08:33,443 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-02-15 14:08:33,445 - Recv: Cap:EMERGENCY_PARSER:0
2020-02-15 14:08:33,447 - Recv: Cap:PROMPT_SUPPORT:0
2020-02-15 14:08:33,448 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-02-15 14:08:33,451 - Recv: Cap:THERMAL_PROTECTION:1
2020-02-15 14:08:33,453 - Recv: Cap:MOTION_MODES:0
2020-02-15 14:08:33,454 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-02-15 14:08:33,455 - Recv: ok
2020-02-15 14:08:33,458 - Send: M21
2020-02-15 14:08:33,473 - Recv: echo:SD card ok
2020-02-15 14:08:33,476 - Recv: ok
2020-02-15 14:08:33,478 - Send: M20
2020-02-15 14:08:33,480 - Recv: Begin file list
2020-02-15 14:08:33,503 - Recv: XYZCAL~1.GCO 1349468
2020-02-15 14:08:33,505 - Recv: SHIFTE~1.GCO 1728888
2020-02-15 14:08:33,506 - Recv: MOVETE~1.GCO 121806
2020-02-15 14:08:33,508 - Recv: SINGLE~1.GCO 71416
2020-02-15 14:08:33,510 - Recv: SHIFTE~3.GCO 5165272
2020-02-15 14:08:33,513 - Recv: End file list
2020-02-15 14:08:33,518 - Recv: ok
2020-02-15 14:08:38,390 - Send: M105
2020-02-15 14:08:38,397 - Recv: ok T:20.32 /0.00 B:20.31 /0.00 @:0 B@:0
2020-02-15 14:08:43,395 - Send: M105
2020-02-15 14:08:43,402 - Recv: ok T:20.22 /0.00 B:19.69 /0.00 @:0 B@:0
2020-02-15 14:08:48,396 - Send: M105
2020-02-15 14:08:48,405 - Recv: ok T:20.00 /0.00 B:19.22 /0.00 @:0 B@:0
Serial.log: Startup the Pi, wait Octoprint to run, then turn on the printer:
2020-02-15 14:34:43,058 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-02-15 14:34:43,082 - Serial port list: ['/dev/ttyACM0']
2020-02-15 14:34:43,082 - Connecting to: /dev/ttyACM0
2020-02-15 14:34:43,087 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-02-15 14:34:43,089 - Connected to: Serial<id=0x70db41b0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-02-15 14:34:43,091 - Starting baud rate detection...
2020-02-15 14:34:43,092 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-02-15 14:34:44,098 - Trying baudrate: 115200
2020-02-15 14:34:44,113 - Send: N0 M110 N0*125
2020-02-15 14:34:44,115 - Recv: ok
2020-02-15 14:34:44,121 - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-02-15 14:34:44,140 - Send: N0 M110 N0*125
2020-02-15 14:34:44,146 - Recv: ok
2020-02-15 14:34:44,151 - Send: N1 M115*39
2020-02-15 14:34:44,155 - Recv: FIRMWARE_NAME:Marlin 2.0.3 (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-02-15 14:34:44,172 - Recv: Cap:SERIAL_XON_XOFF:0
2020-02-15 14:34:44,186 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-02-15 14:34:44,204 - Recv: Cap:EEPROM:Cap:Z_PROBE:0
2020-02-15 14:34:44,215 - Recv: Cap:LEVELING_DATA:1
2020-02-15 14:34:44,218 - Recv: Cap:BUILD_PERCENT:1
2020-02-15 14:34:44,221 - Recv: Cap:SOFTWARE_POWER:0
2020-02-15 14:34:44,223 - Recv: Cap:TOGGLE_LIGHTS:0
2020-02-15 14:34:44,225 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-02-15 14:34:44,228 - Recv: Cap:EMERGENCY_PARSER:0
2020-02-15 14:34:44,231 - Recv: Cap:PROMPT_SUPPORT:0
2020-02-15 14:34:44,233 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-02-15 14:34:44,237 - Recv: Cap:THERMAL_PROTECTION:1
2020-02-15 14:34:44,239 - Recv: Cap:MOTION_MODES:0
2020-02-15 14:34:44,243 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-02-15 14:34:44,245 - Recv: ok
2020-02-15 14:34:44,252 - Send: M21
2020-02-15 14:34:44,269 - Recv: echo:SD card ok
2020-02-15 14:34:44,336 - Recv: ok
2020-02-15 14:34:44,339 - Send: M20
2020-02-15 14:34:44,353 - Recv: Begin file list
2020-02-15 14:34:44,397 - Recv: XYZCAL~1.GCO 1349468
2020-02-15 14:34:44,403 - Recv: SHIFTE~1.GCO 1728888
2020-02-15 14:34:44,405 - Recv: MOVETE~1.GCO 121806
2020-02-15 14:34:44,406 - Recv: SINGLE~1.GCO 71416
2020-02-15 14:34:44,408 - Recv: SHIFTE~3.GCO 5165272
2020-02-15 14:34:44,410 - Recv: End file list
2020-02-15 14:34:44,413 - Recv: ok
2020-02-15 14:34:49,122 - Send: M105
2020-02-15 14:34:49,130 - Recv: ok T:19.34 /0.00 B:19.53 /0.00 @:0 B@:0
2020-02-15 14:34:54,123 - Send: M105
2020-02-15 14:34:54,131 - Recv: ok T:19.56 /0.00 B:19.37 /0.00 @:0 B@:0
2020-02-15 14:34:59,124 - Send: M105
2020-02-15 14:34:59,134 - Recv: ok T:19.34 /0.00 B:19.69 /0.00 @:0 B@:0
Thank you for your kind help in advance!
The web UI came alive, I uninstalled the plugin, but did not solve it. I lost the web UI forever in normal mode.
