Slicer
Name, version, operating system
Cura, 5.9.1, linux X64
I just switched from Slic3r to Cura and now the filament estimation no longer works.
I get: "Tool 0: 0.00m/0.01g" regardless of print time.
Is there a setting in Cura that needs to be turned on, or something in OctoPrint?
I am using Spool manager and this problem might relate to that.
I noticed this difference in the slicers to express the consumption:
Slic3r:
; filament used = 668.6mm (1.6cm3) (at the end of the file)
Cura:
;Filament used: 1.6272m (at the beginning of the file)
So I tried editing the gcode file to use the Slic3r notation (except the volume), but it had no effect.
octoprint-systeminfo-20250330114314.zip (1.9 MB)
Example GCODE file
Please upload here, the forum supports file uploads of GCODE files
UPLOAD HERE
