I'm using a second extruder for supports.
This seems to work.
But I need to add some pre- and post-switch gcode to optimize the process.
My profile has:
preswitchextruder.gcode =
G91
G1 E-15 F300
G90
postswitchextruder.gcode =
G91
G1 E15 F300
G90
But the generated gcode still says:
;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
T1
;This code is added after the T(n)
Looks like these settings are not used.
OctoPrint** : 1.3.9
Did you restart OctoPrint after making the changes?
For other profile related settings, just uploading and reslicing works just fine.
But since I re-tested after upgrading OctoPrint, I can say, that I have actually.
Did not matter.
Do your changes persist in the Settings area, having restarted?
I'm not experiencing any other problems with my settings.
Even if I change something in the same profile (.ini) then these changes do work, like temperature, which is very visible when heating up before printing.
So when you go back to Settings -> Gcode, you see the changes you made earlier?
OMG.. there is a section for these parameters.. that's crazy.
I was editing them in the .ini file as mentioned.
Thought they would change along with all the other settings when I select a slicer profile.
Never mind then.
Thanks.
If it's fixed, make sure to click that icon to indicate so.
