Is there a posibility to implement a slider instead of the, fan on- fan off, buttons?
Best regards Piet.
Best regards Piet.
Great plugin, thanks for mentioning it.
best regards Piet.
Link above - Fan Speed Control: Error 404, page not found.
How to add slider instead of Fan on/off?
Help please.
[ OctoPrint 1.3.12 running on OctoPi 0.16.0 ]
Thank you much!
Not working anymore :_(
Unfortunately, plugin. :_(
Then you may get in contact with the plugin author at ta site (https://github.com/ntoff/OctoPrint-FanSpeedSlider) and raise a issue report.
It looks like the repo has been archived, and is read only.
Upps... That's bad.
I really wanted to use this plugin, but as others have pointed out it's archived (and not compatible with Python 3).
I noticed that there are several forks of this plugin, so I used a trick I've used before: the awesome tool Find Active Forks.
Turns out there's an active fork that has been updated to work with Python 3 and was updated just a month ago. I haven't installed it yet because I'm printing, but it looks promising!
czM1K3/OctoPrint-FanSpeedSlider: Adds a parts fan speed slider to octoprint's UI (github.com)
