Although I keep the Timelapse list in the GUI fairly clean (currently only two items), the folder at /home/pi/.octoprint/data/octolapse/snapshots contains 32 left-behind folders - some recent, some old; most contain only one subfolder which in turn contains only one .csv and one .jpg. Not a problem except that it would seem cleanup is in order. These date back sporadically for the past six months. There are five dated in August (6 months ago or so) and a smattering of a few per month.
Have not taken steps; I would like to delete these (I know how to - but should I?), and would like to know what might be causing them to stick around. It is possible a few might be the result of power failures and the like, but certainly not that many.
I have included an arbitrary log here (Jan 31, a day for which there are three existing folders... Here's the folder information:
drwxr-xr-x 3 pi pi 4096 Jan 31 00:35 18eb2cb3-7056-405b-9732-dbf9ad63b444
drwxr-xr-x 3 pi pi 4096 Jan 31 13:24 41ae92cf-f104-4c32-a255-344e5c7240d8
drwxr-xr-x 3 pi pi 4096 Jan 31 15:39 a8f1d6d6-70d8-47e3-9f0b-247f3e9d7c09
find 18eb2cb3-7056-405b-9732-dbf9ad63b444 \
41ae92cf-f104-4c32-a255-344e5c7240d8 \
18eb2cb3-7056-405b-9732-dbf9ad63b444/354def78-9eea-409a-ad23-ee966dfff4ba
18eb2cb3-7056-405b-9732-dbf9ad63b444/354def78-9eea-409a-ad23-ee966dfff4ba/Neck_Upper_0.1mm_PLA_MK3S_11h44m000000.jpg
18eb2cb3-7056-405b-9732-dbf9ad63b444/354def78-9eea-409a-ad23-ee966dfff4ba/metadata.csv
41ae92cf-f104-4c32-a255-344e5c7240d8/354def78-9eea-409a-ad23-ee966dfff4ba
41ae92cf-f104-4c32-a255-344e5c7240d8/354def78-9eea-409a-ad23-ee966dfff4ba/uk2_v20_NeckJoiner_Lovelady_0.1mm_PLA_MK3S_2h11m000000.jpg
41ae92cf-f104-4c32-a255-344e5c7240d8/354def78-9eea-409a-ad23-ee966dfff4ba/metadata.csv
a8f1d6d6-70d8-47e3-9f0b-247f3e9d7c09/354def78-9eea-409a-ad23-ee966dfff4ba
a8f1d6d6-70d8-47e3-9f0b-247f3e9d7c09/354def78-9eea-409a-ad23-ee966dfff4ba/uk2_v20_Neck_Upper_0.1mm_PLA_MK3S_15h17m000000.jpg
a8f1d6d6-70d8-47e3-9f0b-247f3e9d7c09/354def78-9eea-409a-ad23-ee966dfff4ba/metadata.csv
Here's the log file for that date. Due to size limitations I've dropped a lot from the middle...
2020-01-31 00:32:17,610 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 00:32:17,617 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-01-31 00:32:17,618 - octoprint.server - INFO - OctoPrint 1.3.12
2020-01-31 00:32:17,622 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
| !Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
| MultiCam (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_multicam
| Octolapse (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPrint Anywhere (1.0.20) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere
| OctoVox Plugin (0.1.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octovox
| PauseForUser Event Plugin (0.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_pause_for_user_event
| PrinterAlerts (0.7.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrinterAlerts
| Prusa ETA override Plugin (0.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrusaETAOverride
2020-01-31 00:32:17,640 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2020-01-31 00:32:17,641 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-01-31 00:32:22,195 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Chris_MINI_0.15mm_PLA_MK3S_2h12m.gcode finished, needed 48.82s
2020-01-31 00:32:23,205 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Chris_MINI_0.15mm_PLA_MK3S_2h12m.gcode
2020-01-31 00:32:23,208 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/Chris_MINI_0.15mm_PLA_MK3S_2h12m.gcode
2020-01-31 00:33:10,502 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Chris_MINI_0.15mm_PLA_MK3S_2h12m.gcode finished, needed 47.30s
2020-01-31 00:33:11,514 - octoprint.filemanager.analysis - INFO - Starting analysis of local:NECK_LOWER_0.1mm_PLA_MK3S_15h43m.gcode
2020-01-31 00:33:11,518 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/NECK_LOWER_0.1mm_PLA_MK3S_15h43m.gcode
2020-01-31 00:34:31,112 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h44m.gcode, owner: dennis, user: dennis
2020-01-31 00:34:38,807 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-01-31 00:34:38,823 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:34:38,826 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:34:38,829 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h44m.gcode, owner: dennis, user: dennis
2020-01-31 00:34:38,865 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:34:38,866 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:34:38,994 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-01-31 00:34:39,018 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:34:39,021 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:34:39,029 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-01-31 00:34:40,309 - octoprint.util.comm - INFO - Externally triggered heatup detected
2020-01-31 00:37:18,082 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-01-31 00:37:18,105 - octoprint.filemanager.analysis - INFO - Starting analysis of local:NECK_LOWER_0.1mm_PLA_MK3S_15h43m.gcode
2020-01-31 00:37:18,111 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/NECK_LOWER_0.1mm_PLA_MK3S_15h43m.gcode
2020-01-31 00:37:18,129 - octoprint.util.comm - INFO - Force-sending M108 to the printer
2020-01-31 00:37:18,176 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:37:18,182 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:37:18,198 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h44m.gcode, owner: dennis, user: dennis
2020-01-31 00:37:18,273 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:37:18,276 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:37:21,082 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2020-01-31 00:37:21,107 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:37:21,110 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:37:25,491 - octoprint.timelapse - WARNING - Cannot capture image, image number is unset
2020-01-31 00:40:03,742 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-01-31 00:40:03,760 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:40:03,761 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:40:03,763 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h44m.gcode, owner: dennis, user: dennis
2020-01-31 00:40:03,778 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:40:03,786 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:40:03,876 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-01-31 00:40:03,897 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-01-31 00:40:03,925 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 00:40:03,926 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 00:40:06,791 - octoprint.util.comm - INFO - Externally triggered heatup detected
2020-01-31 00:44:16,255 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.149', 41177), not sending a M-SEARCH reply
2020-01-31 00:47:17,617 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 01:02:17,625 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 01:17:17,629 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 01:32:17,633 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 01:47:17,635 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 02:02:17,636 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 02:17:17,637 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 02:32:17,640 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 02:44:03,623 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.2', 50384), not sending a M-SEARCH reply
2020-01-31 02:44:03,630 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.6', 42365), not sending a M-SEARCH reply
2020-01-31 02:44:07,200 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.149', 41177), not sending a M-SEARCH reply
2020-01-31 02:47:17,641 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 03:02:17,643 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 03:04:35,775 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.149', 41177), not sending a M-SEARCH reply
2020-01-31 03:04:36,490 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.2', 50384), not sending a M-SEARCH reply
2020-01-31 03:04:36,592 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.6', 42365), not sending a M-SEARCH reply
2020-01-31 03:17:17,645 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 03:32:17,646 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 03:47:17,648 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 04:02:17,649 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 04:17:17,651 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 04:32:17,652 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 04:43:49,544 - backoff - INFO - Backing off upload_timelapses(...) for 1931.4s (ConnectionError: HTTPConnectionPool(host='stream.getanywhere.io', port=80): Max retries exceeded with url: /timelapses/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x69744930>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',)))
2020-01-31 04:43:49,612 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.149', 24772), not sending a M-SEARCH reply
2020-01-31 04:43:49,920 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.149', 24772), not sending a M-SEARCH reply
2020-01-31 04:43:53,298 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.2', 50384), not sending a M-SEARCH reply
2020-01-31 04:47:17,656 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 04:47:29,806 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-01-31 04:47:29,928 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch repository from network
2020-01-31 04:47:29,930 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2020-01-31 04:57:34,051 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69814d10>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:57:44,300 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69744310>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:57:54,885 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69653910>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:58:06,149 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69615190>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:58:17,645 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x7313bab0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:58:33,466 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69735570>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:58:49,625 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6964b790>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:59:09,774 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69814df0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 04:59:44,464 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69668850>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:02:17,657 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 05:02:29,854 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-01-31 05:02:30,909 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-01-31 05:02:30,998 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 1.1s
2020-01-31 05:02:31,105 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-01-31 05:02:33,714 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.7s
2020-01-31 05:02:34,695 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-01-31 05:02:34,851 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-01-31 05:02:35,090 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-01-31 05:02:35,091 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-01-31 05:02:35,133 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-01-31 05:02:35,128 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-01-31 05:02:36,954 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.74s
2020-01-31 05:02:37,951 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.88s
2020-01-31 05:02:38,937 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.75s
2020-01-31 05:02:46,533 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-01-31 05:02:46,533 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-01-31 05:02:47,232 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-01-31 05:17:17,661 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 05:17:32,914 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-01-31 05:18:10,634 - backoff - INFO - Backing off upload_timelapses(...) for 2135.2s (ConnectionError: HTTPConnectionPool(host='stream.getanywhere.io', port=80): Max retries exceeded with url: /timelapses/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6979ba50>: Failed to establish a new connection: [Errno 110] Connection timed out',)))
2020-01-31 05:28:56,244 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x697fb5f0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:29:06,657 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6963eaf0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:29:17,191 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6963e950>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:29:28,050 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x697166f0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:29:39,720 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6963e8b0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:29:53,491 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6963e250>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:30:09,221 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69615190>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:30:42,342 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6963eb50>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:31:12,067 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69664a30>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:32:13,790 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x6979bff0>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:32:17,666 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 05:34:36,994 - octoprint.plugins.anywhere - ERROR - (<urllib3.connection.HTTPConnection object at 0x69751f50>, 'Connection to stream.getanywhere.io timed out. (connect timeout=<object object at 0x76ca74c0>)')
2020-01-31 05:47:17,673 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 05:47:36,161 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-01-31 05:47:36,187 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-01-31 05:47:37,307 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-01-31 05:50:14,379 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-01-31 05:50:14,380 - octoprint.filemanager.analysis - INFO - Starting analysis of local:NECK_LOWER_0.1mm_PLA_MK3S_15h43m.gcode
2020-01-31 05:50:14,383 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/NECK_LOWER_0.1mm_PLA_MK3S_15h43m.gcode
2020-01-31 05:50:14,386 - octoprint.util.comm - INFO - Force-sending M108 to the printer
2020-01-31 05:50:14,436 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 05:50:14,437 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 05:50:14,470 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h44m.gcode, owner: dennis, user: dennis
2020-01-31 05:50:14,657 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 05:50:14,658 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 05:50:15,142 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2020-01-31 05:50:15,158 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 05:50:15,161 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 05:54:18,428 - octoprint.printer.standard.job - INFO - Print job deselected - user: n/a
2020-01-31 05:55:20,934 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h58m.gcode, owner: dennis, user: dennis
2020-01-31 05:55:24,316 - octoprint.printer.standard.job - INFO - Print job deselected - user: n/a
2020-01-31 05:55:46,706 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h58m.gcode, owner: _api, user: _api
2020-01-31 05:55:46,745 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-01-31 05:55:46,761 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Neck_Upper_0.1mm_PLA_MK3S_11h58m.gcode, owner: _api, user: _api
2020-01-31 05:55:46,779 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 05:55:46,780 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 05:55:46,816 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 05:55:46,820 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 05:55:47,242 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-01-31 05:55:47,598 - octoprint.plugins.octovox - INFO - Stopping Timer...
2020-01-31 05:55:47,608 - octoprint.plugins.octovox - INFO - Starting Timer...
2020-01-31 05:55:47,614 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-01-31 05:56:56,405 - octoprint.util.comm - INFO - Externally triggered heatup detected
2020-01-31 06:02:17,674 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 06:04:24,020 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.2', 50384), not sending a M-SEARCH reply
2020-01-31 06:04:24,031 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.6', 42365), not sending a M-SEARCH reply
2020-01-31 06:17:17,675 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 06:32:17,677 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-01-31 06:43:42,893 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.2', 50384), not sending a M-SEARCH reply
2020-01-31 06:43:42,899 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.158.6', 42365), not sending a M-SEARCH reply
<block deleted for brevity...>
(::ffff:192.168.158.70) 2.76ms
2020-02-01 11:07:34,086 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 11:08:23,104 - tornado.access - WARNING - 403 GET /sockjs/websocket (::ffff:192.168.158.180) 3.20ms
2020-02-01 11:22:34,088 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 11:37:34,091 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 11:52:34,092 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 12:07:34,094 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 12:22:34,096 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 12:37:34,098 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 12:52:34,099 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-01 13:07:34,101 - octoprint.server.heartbeat - INFO - Server heartbeat <3
Serial log seems to be disabled, and I don't expect it's needed for this question. let me know if you need more niformation.
cat serial.log
2020-02-03 16:02:29,260 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
OctoPrint 1.3.12, Prusa I3 MK3S, Octopi 0.15.0 - all that's needed is in the question or in the log.
