Snapshot URL not working
My webcam is: IP Webcam - Apps on Google Play
The server says the URL is not valid and it doesn't start the print.
My octoprint version is Octopi 0.18.0 with Octoprint 1.7.2
Ohh yeah and the stream works fine with the webcam.
Screenshots:
Thanks!
What URL are you trying to use as a snapshot URL? If the print is refusing to start this is usually an error from OctoLapse, so you should go and check it's settings.
I actually just solved the problem today, (the error was in the URL end: /photo.jpg is what finally worked). Thanks for the help though.
