PI Camera with ribbon
no Picture in Octoprint
Camera plugged into ribbon connector, leagecy mode must be off, sudo apt-get install libcamera-apps, libcamera-hello OK
**Logs** (`/var/log/webcamd.log` is empty,
cat /var/log/syslog | grep bcm2835,
Nov 2 22:15:54 octoprint kernel: [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:BD:BC:6D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=00ca95f2-02 rootfstype=ext4 fsck.repair=yes rootwait
Nov 2 22:15:54 octoprint kernel: [ 0.087311] bcm2835-mbox fe00b880.mailbox: mailbox enabled
Nov 2 22:15:54 octoprint kernel: [ 0.171271] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
Nov 2 22:15:54 octoprint kernel: [ 1.299365] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
Nov 2 22:15:54 octoprint kernel: [ 1.484478] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
Nov 2 22:15:54 octoprint kernel: [ 1.921561] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Nov 2 22:15:54 octoprint kernel: [ 1.930591] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Nov 2 22:15:54 octoprint kernel: [ 1.941738] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
Nov 2 22:15:54 octoprint kernel: [ 2.884085] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
Nov 2 22:15:54 octoprint kernel: [ 6.672836] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Nov 2 22:15:54 octoprint kernel: [ 6.686161] bcm2835_audio bcm2835_audio: card created with 8 channels
Nov 2 22:15:54 octoprint kernel: [ 6.690038] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Nov 2 22:15:54 octoprint kernel: [ 6.705040] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Nov 2 22:15:54 octoprint kernel: [ 6.720938] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
Nov 2 22:15:54 octoprint kernel: [ 6.728689] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Nov 2 22:15:54 octoprint kernel: [ 6.730495] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
Nov 2 22:15:54 octoprint kernel: [ 6.735406] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
Nov 2 22:15:54 octoprint kernel: [ 6.735546] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Nov 2 22:15:54 octoprint kernel: [ 6.735920] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
Nov 2 22:15:54 octoprint kernel: [ 6.736300] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
Nov 2 22:15:54 octoprint kernel: [ 6.736339] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.736363] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.736392] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.736409] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.743098] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Nov 2 22:15:54 octoprint kernel: [ 6.743449] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
Nov 2 22:15:54 octoprint kernel: [ 6.743910] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
Nov 2 22:15:54 octoprint kernel: [ 6.744303] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
Nov 2 22:15:54 octoprint kernel: [ 6.744639] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
Nov 2 22:15:54 octoprint kernel: [ 6.744673] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.744707] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.744748] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.744765] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Nov 2 22:15:54 octoprint kernel: [ 6.745023] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
Nov 2 22:15:54 octoprint kernel: [ 6.783326] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Nov 2 22:15:54 octoprint kernel: [ 6.783387] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Nov 2 22:15:54 octoprint kernel: [ 6.791267] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Nov 2 22:15:54 octoprint kernel: [ 6.791321] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Nov 2 22:15:54 octoprint kernel: [ 6.797741] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Nov 2 22:15:54 octoprint kernel: [ 6.797805] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Nov 2 22:15:54 octoprint kernel: [ 6.802934] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
Nov 2 22:15:54 octoprint kernel: [ 6.802994] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
Nov 2 22:15:54 octoprint kernel: [ 6.808677] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
Nov 2 22:15:54 octoprint kernel: [ 6.808734] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
grep: (Standardeingabe): Übereinstimmungen in Binärdatei
dmesg | grep bcm2835
[ 0.086757] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.172715] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 1.285196] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.470021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.885036] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.894706] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.904444] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.913704] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 6.571784] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.587397] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.599258] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.607001] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.607557] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.607954] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.608519] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.608557] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.608578] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.608596] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.608612] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.614879] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.615164] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.615596] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.615959] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.616294] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.616330] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.616351] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.616368] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.616384] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.616619] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.621721] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.632826] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.638458] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.672119] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.689594] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.689658] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.698911] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.698979] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.710240] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.710299] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.713729] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.713779] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.718104] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.718180] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
OS: Debian GNU/Linux 11 (bullseye) aarch64
Host: Raspberry Pi 4 Model B Rev 1.5 1024 MiB
Kernel: 5.15.74-v8+
* * OctoPrint 1.8.6 Python 3.9.2 ** (OctoPrint version, OctoPi version, ...)
pi@octoprint:~ $ libcamera-hello
Preview window unavailable
[0:32:49.758343437] [1383] INFO Camera camera_manager.cpp:293 libcamera v0.0.1+21-7c855784
[0:32:49.785127233] [1384] INFO RPI raspberrypi.cpp:1414 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media4 and ISP device /dev/media0
[0:32:49.785836334] [1383] INFO Camera camera.cpp:1026 configuring streams: (0) 1296x972-YUV420
[0:32:49.786152515] [1384] INFO RPI raspberrypi.cpp:800 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
pi@octoprint:~ $ raspistill
-bash: raspistill: Command not found
libcamera-jpeg --list-cameras
Available cameras
0 : ov5647 [2592x1944] (/base/soc/i2c0mux/i2c@1/ov5647@36)
Modes: 'SGBRG10_CSI2P' : 640x480 [58.92 fps - (16, 0)/2560x1920 crop]
1296x972 [43.25 fps - (0, 0)/2592x1944 crop]
1920x1080 [30.62 fps - (348, 434)/1928x1080 crop]
2592x1944 [15.63 fps - (0, 0)/2592x1944 crop]
[0:41:56.952675530] [1471] INFO Camera camera_manager.cpp:293 libcamera v0.0.1+21-7c855784
[0:41:56.984963902] [1472] INFO RPI raspberrypi.cpp:1414 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media4 and ISP device /dev/media0
[0:41:56.985760002] [1471] INFO Camera camera.cpp:1026 configuring streams: (0) 1296x972-YUV420
[0:41:56.986063498] [1472] INFO RPI raspberrypi.cpp:800 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
[0:42:02.133835178] [1471] INFO Camera camera.cpp:1026 configuring streams: (0) 2592x1944-YUV420 (1) 2592x1944-SGBRG10_CSI2P
[0:42:02.136984821] [1472] INFO RPI raspberrypi.cpp:800 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 2592x1944-SGBRG10_1X10 - Selected unicam format: 2592x1944-pGAA
Still capture image received
$ ls test*
An image is saved
raspi-config -> legency camera off
/boot/config no entries for camera
http://octoprint.local/webcam/?action=stream 503 Service Unavailable
type or paste code here
