When I press "connect" in the Octoprint web page, it says "connecting" for a while and then returns to "offline."
- Lowering baud rate
- Reboot in safe mode
- Disable automatic firmware detection
- Disable blacklist
- Restart octoprint
- Restart web page
- A fair amount of googling
OctoPrint v. 1.3.11 running on Orange Pi Zero (Armbian latest version)
Printer: Anycubic i3 Mega
Printer fw: v1.1.0
Terminal:
Connecting to: /dev/ttyUSB0Changing monitoring state from "Offline" to "Opening serial port"Connected to: Serial<id=0xb14eccb0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitorChanging monitoring state from "Opening serial port" to "Connecting"Send: N0 M110 N0125Recv: �Np|�_HH5�P��JpON6��Z�zRecv: %�h�on\x0cm7�nn\x19|&~�h&�H�X�J\x13\x03�~�A\x0c\x086�M�7��-\x0c\x07*&�]\x03\x0bMbO6\x17d6�p|��H\x13H6f�J�JJ�8J�(K�J?JKp|~H\x0f^\x17l**\x07J�Z��I��I�k\x08�HJp|~\x18�\x0b^>h�$p|\x084\x08�A\x08�J\x08�J�%�X�\x1a�\x0b^>Y�N66\x0b�^^aHM�6�p|\x084\x08�AHJ�AHJ�AHJp|@_a�&&��$M\x0fM6\x03lI$M^\x0bj�6\x03lI�6X\x0f\x0bH>\x03�4�&('�hI�&(n~lI�&\x18n~lX�J�Z�I�j\x08�J�(%�8%�(�J_�X��Mah\x04\x07J�J�I�j\x08N�X��\x0b�N6�\x0bh$p|\x08�Recv: N�X�:6\x136l6N&\x1b^f�J�[�(%\x08\x08M0�[�(J\x08-H\x07Recv: \x16jO6�f�J�Z�5hE.�\x08[�f�There was a timeout while trying to connect to the printerChanging monitoring state from "Connecting" to "Offline"Connection closed, closing down monitor
Octoprint log: octoprint.log (187.9 KB)
Note: I had Octoprint running fine on basically the same setup before, but had wifi issues with my Orange Pi Zero. I have replaced with another OP Zero and re-installed.
regards,
Sean
