Solved
I removed brltty via sudo apt -y remove brltty and rebooted. It was stealing the USB connection.
tl;dr I have a brand new Octoprint + Ubuntu installation and a brand new NUC 11 and it won't connect to my Neptune 3 pro
I have Octoprint v1.8.7 running on Ubuntu 22.04.2 LTS on a NUC 11, connected to an Elegoo Neptune 3 Pro via a brand new printer data USB cable.
Initially, I installed the same setup on an old intel-based computer in a tower (and everything worked great!), but the computer tower is enormous and I wanted to replace it with something much smaller. So, NUC it is.
I installed Octoprint and the webcam support according to this tutorial on both computers, and am now having issues getting the NUC to connect to the printer.
When I try to connect to the printer (selecting Auto for everything), Octoprint doesn't connect to the printer. Looking at the Terminal output, it wants to select /dev/ttyS4, but times out.
I have a feeling this is something silly and simple that I forgot. Any ideas?
Sample output:
Trying port /dev/ttyS4, baudrate 115200
Connecting to port /dev/ttyS4, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x7fcae40fb010, open=True>(port='/dev/ttyS4', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Handshake attempt #2 with timeout 2.0s
Handshake attempt #3 with timeout 2.0s
Trying port /dev/ttyS4, baudrate 250000
... and so on
I tried the debugging steps on the debugging tips page.
- I tried selecting
/dev/ttyS4manually and all of the available baudrates, but it can't connect - I tried enabling
Wait for Start on connect, but it can't connect - Tried upping timeouts and attempts, but it can't connect
- I tried plugging the printer into several other USB ports on the device; none of them seem to be the correct one (front and back ports)
I did! It booted up with the message:
Safe mode is active
The server is currently running in safe mode. Third party plugins and language packs are disabled and cannot be enabled.
Reason: Setting in config.yaml
octoprint-systeminfo-20230325230305.zip (22.8 KB)
