What is the problem? Pause works just fine (code below), but upon resume, the print head moves back into position and then the extruder pumps out a bunch of mat'l for no reason.
It's almost like the printer is trying to "undo" the G1 E-80 F1000 move on its own. By the way, my printer is a Delta (SeeMeCNC RoStock v2). Octoprint 1.4.0 running on OctoPi 0.17.0
What did you already try to solve it? I removed all 'resume' gcode.
Here is the custom gcode script in the 'after print job is paused'
G91 ; Relative movement
G1 Z5 ; Move head away vertically
G1 E-6 F1000; Retraction move, take away filament pressure
G90 ; Absolute position ON
G1 Y-100 ; Move to front position
G91; Relative movement
G1 E-80 F1000; retract filament into bowden for easier swap
G90; Absolute position ON
Here is the 'Before print job is resumed' (Nothing)
Terminal commands just prior to the pause event
Send: N2879 G1 X10.817 Y5.078 E266.01017*102
Recv: ok
Send: N2880 G1 X10.423 Y5.844 E266.0645*92
Changing monitoring state from "Printing" to "Pausing"
Recv: ok
Send: N2881 G1 X9.964 Y6.595 E266.12003*94
Recv: ok
Send: N2882 G1 X9.466 Y7.293 E266.17411*80
Recv: ok
Send: N2883 M400*22
Recv: ok
Send: N2884 M114*17
Recv: ok
Recv: ok
Recv: X:9.47 Y:7.29 Z:2.900 E:266.1688
Send: N2885 M105*16
Recv: ok
Send: N2886 G91*37
Recv: T:205.36 /205 B:59.75 /60 B@:106 @:91
Recv: ok
Send: N2887 G1 Z5*82
Recv: ok
Send: N2888 G1 E-6 F1000*11
Recv: ok
Send: N2889 G90*43
Recv: ok
Send: N2890 G1 Y-100*126
Recv: ok
Send: N2891 G91*35
Recv: ok
Send: N2892 G1 E-80 F1500*59
Recv: ok
Send: N2893 G90*32
Recv: ok
Changing monitoring state from "Pausing" to "Paused"
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Terminal command after resume
Recv: wait
Recv: wait
Changing monitoring state from "Paused" to "Resuming"
Changing monitoring state from "Resuming" to "Printing"
Send: N6781 G0 F3600 X-2.776 Y8.536 Z6.6*6
Recv: ok
Send: N6782 G1 F600 Z5.6*20
Recv: ok
Send: N6783 G1 F2700 E553.84918*53
Recv: ok
Send: N6784 G1 X-1.972 Y9.34 E553.92091*65
Recv: ok
Send: N6785 G0 F3600 X-1.972 Y10.047*101
Recv: ok
Send: N6786 G1 F2700 X-3.953 Y8.067 E554.09759*16
Recv: ok
Send: N6787 G1 X-4.041 Y7.979*59
Recv: ok
Send: N6788 G1 F2700 E551.09759*50
Recv: ok
Send: N6789 G1 F600 Z6.6*28
Recv: ok
Send: N6790 G0 F3600 X1.837 Y-8.581 Z6.6*3
Recv: ok
Send: N6791 M106 S255*92
Recv: ok
Recv: Fanspeed:255
Send: N6792 G0 X1.837 Y-8.581 Z6.9*109
Recv: ok
Send: N6793 G1 F600 Z5.9*27
Recv: ok
Send: N6794 G1 F2700 E554.09759*58
Recv: ok
Send: N6795 G1 F835.5 X2.56 Y-8.392 E554.14473*1
Recv: ok
Send: N6796 G1 X3.275 Y-8.141 E554.19253*118
Recv: ok
octoprint.log (32.6 KB)
