Solved: Lightning bolt power warning
So just posting this here since I didn't come across the solution searching the forums before I fixed this:
I had my Pi wired to the standby power on an ATX power supply and I was always getting the lightning bolt power warning. Googling led me to believe it was just one of the risks of using the standby line but turns out the problem was something else.. the wire I was using. I had hacked off the micro USB connector on one end of a cable and the wires were just not up to the task. I ordered some micro USB ends and soldered on some thicker wire and problem solved!
Also note, on a different build I had problems in the past powering the pi4 through the GPIO pins I was able to solve that again by buying a usb-c connector and attaching to that instead... so seems like buying usb ends and soldering is the way to go.
Check the ratings on the 5v standby on the PS label. Most ATX supplies are only rated 1 amp or less on that line
There are already advices on using proper wires on powering the Pi in various threads.
Using "Solved" in the topic is a bit misleading, because you did not came in with a help query but more with a advice.
Also because this forum software uses a different way for marking solved threads.
It's my understanding that modern ATX power supplies have 3A now and it's been a long time since most were 1A. For example here are the specs on mine even the 450w has 3A.
https://www.evga.com/articles/archive/01103/evga-b3-series-power-supplies/default.asp
I simply posted some helpful information I searched for on these forums and failed to find.
