Hello, I’m on the latest OP and it has been running perfect. However, I just upgraded from Marlin 2.0.5 to 2.0.5.3. I used the same config files when compiling both. However I did change the ARC parameters from the ArcWelder thread. However, after it runs the start code(which heats up the heaters and prints a prime line) it fails.
It says it failed in the web interface, but the printer LCD doesn’t show anything. The serial output just shows this. I’ll pull the other logs soon, but I’m not sure they would show anything. Does anyone have any ideas as to what might cause this.
Send: N34 G1 F1800 E-19
Recv: ok
Send: N35 G1 F3000 Z203
Recv: ok
Send: N36 G9037
Recv: ok
Send: N37 G28 X Y38
Recv: echo:busy: processing
Recv: X:220.00 Y:220.00 Z:22.00 E:-1.00 Count X:17600 Y:17600 Z:35200
Recv: ok
Changing monitoring state from "Printing" to "Operational"
