Since I change from a rpi 2 B+ to a rpi 3 B+ the connection stop during the printing session.
I do not have access on browser and via ssh, the print is not affected.
I had format my SD samsung Evo 32Go and put a fresh install for the new rpi 3 B+
The rpi 3 B+ is conncted to the lan on Wifi 5G
I never have had this problem with my rpi 2+, maybe I should pass to regular 2.4ghz wifi. ?!
It is now the second time it occures and my print still in progress, so I had do nothing yet.
I will edit this post later if I can to post the logs. For now my print still running and can not restart the raspberry until it's finish.
rpi 3+ connected on Wifi 5Ghz
When the problem occured, the rpi disappear from the lan client list.
