Can't use any plugin using GPIO
Running Octopi as root
Logs (octoprint.log, serial.log or output on terminal tab, ...)
2019-07-08 22:26:31,111 - octoprint.plugins.enclosure - INFO - Setting GPIO mode to BCM
2019-07-08 22:26:31,117 - octoprint.plugins.enclosure - INFO - Setting GPIO pin 26 as OUTPUT with initial value: 1
2019-07-08 22:26:31,285 - octoprint.plugins.enclosure - WARNING - An exception of type RuntimeError occurred on write_gpio when writing on pin 26. Arguments:
('The GPIO channel has not been set up as an OUTPUT',)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
Latest firmware, Raspberry Pi 2
You might try running this manually using sudo from the command prompt.
# Temporarily elevate our rights to become root
sudo -i
# Export pin 26 so that it appears in the device tree
echo "26" > /sys/class/gpio/export
# Set GPIO 26 as an output port
echo "out" > /sys/class/gpio/gpio26/direction
# Exit from our elevated rights shell
exit
Working great, any way for making it permanent (on reboot ect...) ?
Let's see... I think the pin export is persistent; it will continue to report the pin status to the device tree after a reboot. And I see no reason why the direction wouldn't persist. Why not reboot it and do a cat /sys/class/gpio/gpio26/direction to verify that it's still set to out?
cat: /sys/class/gpio/gpio26/direction: No such file or directory
after reboot.
root@octopi:~# echo "26" > /sys/class/gpio/export
root@octopi:~#
root@octopi:~# cat /sys/class/gpio/gpio26/direction
in
Wow, it looks like something changed in Raspbian so that the device tree state doesn't persist between boots.
Try this:
sudo nano /etc/rc.local
...and add this:
And then reboot with sudo reboot. In theory, rc.local runs as root so you wouldn't need to sudo inside that.
I did what you said, after a week and multiple reboot, everything hold up, thanks !
