There were no changes (figured out that there was an update of the plugin Cancel Objects) since i uploaded some gcode-files yesterday but today i get an error uploading files. I am using Firefox on Windows 10 to upload files. My Raspberr Pi is connected via WiFi. The error says:
Upload failed
(Translated) Could not upload the file. Please make sure, it is a readable valid file with one of the following extensions: .g, .gco, .gcode, .stl, .stl
Internal Server Error
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
Tried other files, rebooted Pi, Reset Printer
2020-01-08 10:21:18,916 - octoprint - ERROR - Exception on /api/files/local [POST]
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1817, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1477, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1381, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1475, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1461, in dispatch_request
return self.view_functionsrule.endpoint
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 1276, in decorated_view
return no_firstrun_access(flask_login.login_required(func))(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 1295, in decorated_view
return func(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask_login.py", line 758, in decorated_view
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/api/files.py", line 361, in uploadGcodeFile
display=canonFilename)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius/init.py", line 546, in new_add_file
return self._file_manager.original_add_file(destination, path, file_object, links, allow_overwrite, printer_profile, None, display)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/filemanager/init.py", line 493, in add_file
path_in_storage = self._storage(destination).add_file(path, file_object, links=links, printer_profile=printer_profile, allow_overwrite=allow_overwrite, display=display)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/filemanager/storage.py", line 765, in add_file
file_object.save(file_path)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/filemanager/util.py", line 92, in save
shutil.copyfileobj(source, dest)
File "/usr/lib/python2.7/shutil.py", line 63, in copyfileobj
buf = fsrc.read(length)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/filemanager/util.py", line 194, in read
processed_line = self.process_line(line)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_cancelobject/init.py", line 37, in process_line
line = self._matchComment(line)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_cancelobject/init.py", line 45, in _matchComment
line = line.decode("utf-8", "strict")
File "/home/pi/oprint/lib/python2.7/encodings/utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xb0' in position 46: ordinal not in range(128)
Octoprint: 1.3.12
Printer: Prusa i3 MK3s
Printer Firmware: 3.8.1
