Hey everyone, I Have some smaller Problems, setting up mjpg-streamer on my "headless Laptop"
But first I must thank all of you i got nearly evrey stone out of my way by this great wiki/community thumbsup
Problem: I cant reach my USB webcam via OctoPrint or directly via "http://laptop-ip:8080/?action=stream"
This is the Way i start it:
./mjpg_streamer -i "./input_uvc.so -f 5 -d /dev/video1" -o "./output_http.so"
MJPG Streamer Version: git rev: 8cc9d22c1e79905d529a248ccf05bbf0625e0bf3
i: Using V4L2 device.: /dev/video1
i: Frames Per Second.: 5
i: Format............: JPEG
i: Could not obtain the requested pixelformat: MJPG , driver gave us: YUYV
... will try to handle this by checking against supported formats.
... Falling back to YUV mode (consider using -yuv option). Note that this requires much more CPU power
i: FPS coerced ......: from 5 to 30
i: Frame period time ......: 200 ms
o: www-folder-path......: disabled
o: HTTP Listen Address..: (null)
o: commands.............: enabled
but i cant reach it anyway..
I first tried the "input_testpicture" mode witch i didn`t get to work.
I tried another device (dev/video0) the internal webcam
I did not "modify" octopi.txt because it is not OctoPI and i did not find any information on a Debian setup instead of Rasbian. (Wich i used before) maybe if you could point me somewhere in that direction...
Octoprint v 1.3.6 on Ubuntu 17.10 Kernel 4.13.0-21-generic without X server on a Asus eee 1005 Atom processor 32bit..
sorry im not native english.
