I'm a bit new to Octoprint... it's been working pretty well so far, but lately, the issues I've been seeing seem to be due to "space" issues on the SD card. I have an 8gb card in there right now, which I figured would be plenty as I didn't plan on keeping old print files on there. The only one I have on there currently is only 5mb.
I recently tried to upgrade Octoprint and that's when I first saw the space error. Then I removed some print files and tried again, got the error again. I tried to add the Spaghetti Detective plugin and got the space issue. I gave up trying to update or add a plugin and went back to uploading the occasional print and using the cam to monitor, which worked fine until this morning.
After the first successful upload and print, I deleted it and tried to upload a 35mb print file and got another space error, so I gave up and am printing via local SD card at the moment.
Is there a possibility that the failed installs left trash files on my card? I'm a bit new to linux, so I apologize in advance for my noobness.
I'm using a Raspberry Pi 4 model b with an 8gb micro sd card (can't remember the brand, but it's a brand name) and here are the versions of Octoprint and plugins I'm using:
OctoPrint : 1.3.12
Automatic Shutdown : 0.1.4
Autoscroll : 0.0.2
Change Filament Plugin : 0.3.0
FileManager Plugin : 0.1.3
Fullscreen Plugin : 0.0.4
Multi Colors : 1.0.16
Themeify : 1.2.0
WebcamStreamer Plugin : 0.1.1
Thanks,
octoprint.log (336 KB)
