Is there a way to shutdown only the OctoPrint Server without shutdown the raspberry?
Octoprint installed on Raspbian
Assuming OctoPi:
sudo systemctl stop octoprint
It says:
Failed to stop octoprint.service: Unit octoprint.service not loaded.
But i can open it in the browser.
Ah nevermind I missed the Raspbian bit. Can't really say as it depends on how you installed it.
If you have fallowed the guide "Setting up OctoPrint on a Raspberry Pi running Raspbian or Raspberry Pi OS" you can see in the "Automatic start up" section the command:
sudo service octoprint {start|stop|restart}
I'd expect the same result since service is essentially just a wrapper for systemd's systemctl. Curious to find out though.
So in some way your install appears to be non-standard. You can search which process it is by
ps aux|grep octoprint
dp 3372 0.0 0.0 7680 548 pts/0 S+ 20:57 0:00 grep --color=auto octoprint
pi 27692 9.7 13.3 443100 118840 ? Ssl Mar07 306:22 /home/pi/oprint/bin/python3 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
which yields 2 processes when I do that here, my search and the server. You can ignore the search, it has already finished once you read the output. If you want to just terminate the server process, the command 'kill' will do that.
sudo kill -s KILL 27692
In spite of it's name kill just sends a signal to the process identified by the process id (27692 in this example). And the signal is KILL. A request to self-destruct.
