What is the problem? I would like to know is their away to get the state information panel to display aree a sole site. Reason is I would like to display this in OBS Recording software so I can see the time left and all that on the recording
What did you already try to solve it? Nothing looking for help if it can be done
I am currently on OctoPrint : 1.3.10 with my Ender 3
Note that bringing up and running a second browser on OctoPrint during a print can have performance issues, especially the part where it first starts. (This will slam one of the cores of the Raspberry to 100% for perhaps 15 seconds or more.)
In theory, something like curl could be used to fetch the home page and then a regex command could just simply remove everything that you're not interested in. It would leave just the side widget that you're interested in. This technique is called "screen-scraping" and was used for years on the Internet to get/steal content from other websites.
All this strikes me as unnecessarily burdening the OctoPrint instance, though, since you're throwing away all that work. A better solution would be to code up something by just querying the REST API and then creating a report that includes the information you're looking for.
If you use NodeJS/JavaScript, you might find the octo-client useful.
Honestly was hopping someone had something built already I mean I can build something for sure I guess to pull the api but was just wondering if someone had anything before I invent the wheel if it has already been made.
Nope. I will say that either Windows or macOS had this Desktop Widget thing in which you could drag a rectangle on some website and then this operating system would go fetch that content and put it on your Desktop. For the reasons above, I would suggest that this would bog down the performance of your Raspberry, though.
