State: Offline (Error: No more candidates to test, and no working port/baudrate combination detected.) What did you already try to solve it?
rebooted raspberry pi 4 and still same error. only connects when i restart both printer and rasp pi 4 Logs (/var/log/webcamd.log, syslog, dmesg, ... no logs, no support)
just paste them here?? Additional information about your setup (OctoPrint version, OctoPi version, ...)
octopi v.1.5.2
ender 3 running BIGTREETECH Direct SKR Mini E3 V2.0
this happened after 12+ print. printer just stops moving. and i cannot ping raspberry pi. only after i restart the raspberry pi can i connect to interface but will not connect to printer
Ok I will do that. So it is able to connect. It was printing over 12 hours and then the nozzle stopped and I noticed I can’t access octo pi. Hit paused on the printer controller and power cycled octopi(while printer paused) then octopi loaded up and couldn’t connect and I get the error. Only when I reboot with printer and octopi does it work again. But I will ssh to pi
