I am trying to setup a static IP address for my Pi on a school setting. No access to the router, IT takes forever to help.
I cannot ping my DNS server on any computer, we do not use something like Google by default, we are using something like
I just need to:
Confirm my static setup is ok
Know how to check if my address is now static
Here is my setup:
interface eth0
static_ip_address=10.136.25.162/24
static routers=10.136.25.1
static domain_name: I Used the default Pi one here, the actual DNS server is 10.136.0.26, however as I said i cannot reach that or the backup.
The setup seems to work, I am connected... will this be ok?
