With the new version .18 the progress stays at 0% on my SR10s Pro V2
also using a plugin for ETA and that is no longer showing either on the display.
how can I make the percentage to work again on the display? (right under the temperature)
thanks
thanks
octoprint.log (405.3 KB) Problem: not showing % completed anymore and no ETA
What did I do to resolve it... nothing... only .17 seems to work for it.
Run Safe mode solve it,, No
2021-01-31 20:24:45,488 - octoprint.printer.standard - ERROR - Exception while sending print progress to plugin display_eta
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/printer/standard.py", line 327, in call_plugins
plugin.on_print_progress(storage, filename, progress)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1890, in wrapper
return f(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_display_eta/__init__.py", line 61, in on_print_progress
if (doM117 == True):
NameError: name 'doM117' is not defined
It looks like the plugin has an error in it, so the progress is not reported. You could report it to the plugin author here: AlexVerrico/Octoprint-Display-ETA
Alternatively, there is also Detailed Progress plugin, that does a similar thing. You could try that one instead.
Thank you.
I reported it on his Github
