In "Control" if you click on X/Y "Home" and then "Extrude" or z Up/Down carriage will start slowly drifting in all 3 directions fore some time and then execute requred command. If you repeat same command that effect will not show but if you repeat X/Y "Home" it will do it again.
Had the same behavior with the stock Anet firmware sometimes, could not be reproduced reliably, so I didn't bother to investigate further.
I recommend you flash Marlin, it's easy to configure and already has a pretty good preset for the A8 built in. I had no such problems since I run Marlin on mine.
Don't like Marlin. Tried it several times and returned back to original Anet A8 stock firmware. Works pretty good for me while Marlin nothing but problems.
@TazerReloaded fullack - my A8 did strange things as well. @red_star_rc your choice and if you open your uploaded serial.log you'll see a special message just for you
G28 X0 Y0 Z0 executed as it supposed to. However after that if you go to Octoprint "Control" and click on for example - move z 10mm UP it does drift all axes and extruder for a while. Then it works as normal.
Same happens if after G28 X0 Y0 Z0 you click on "Extrude"
However if after G28 X0 Y0 Z0 you click on "Move Y 10mm forward" it moves X 10mm back
If after G28 X0 Y0 Z0 you click on "Move X 10mm forward" it moves X and Y 10mm back.
You might try to run these one at a time in the Terminal tab. Report back if anything does something wrong. Moving X should move X and not Y, for example. Moving Z using a positive value should make the extruder higher in relation to the bed. (In some cases OctoPrint's printer profile needs you to check the invert checkbox otherwise.)
G28 # Nothing else. This should home X/Y/Z & E
G90 # Set motors to absolute mode
M83 # Set extruder to relative mode
G0 E10.0 # Extrude 10mm in relative mode
G1 X60.0 # Move the X axis to absolute position X=60.0
G1 Y60.0 # Move the Y axis to absolute position Y=60.0
G1 Z60.0 # Move the Z axis to absolute position Z=60.0
M82 # Set extruder to absolute mode
G92 E0 # Zero the extruder
G1 E10.0 # Extrude 10mm in absolute mode
G4 P5 # Wait five seconds
G1 E20.0 # Extrude another 10mm in absolute mode
So running those commands individually gave you the expected behavior? If so, then it's possible that something is giving odd absolute-versus-relative commands which compete with each other.
my Octoprint wont connect to my printer all of a sudden, but in pi, i can see it......
[ 80.543196] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 82.428832] usb 1-1.3: New USB device found, idVendor=11f1, idProduct=251d, bcdDevice= 1.00
[ 82.428838] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=3
[ 82.428843] usb 1-1.3: SerialNumber: 3FM3WPUS5TH8A60472
[ 82.470535] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 82.472293] usbcore: registered new interface driver cdc_acm
[ 82.472297] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Connecting to: /dev/ttyACM0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0xaae10630, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
No answer from the printer within the connection timeout, trying another hello
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
tried resetting everything, multiple times at this point, i can't figure out what is going wrong.
I am sorry i am new to the forums and i did not know how to start a new help topic at the time, i have learned that now, and i have fixed this issue as well. you may delete it if you need to. sorry about that.
