Can this:
2020-06-21 00:36:09,668 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-06-21 00:36:11,779 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2020-06-21 00:50:18,729 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-06-21 00:51:09,716 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-06-21 00:51:09,782 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-06-21 00:51:10,535 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.79s
2020-06-21 00:51:10,674 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.65s
2020-06-21 00:51:11,015 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-06-21 00:51:11,154 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.22s
2020-06-21 00:51:11,285 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.27s
2020-06-21 00:51:12,545 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.23s
2020-06-21 00:51:12,556 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.24s
2020-06-21 00:51:12,867 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.25s
2020-06-21 00:51:12,883 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.25s
2020-06-21 00:51:13,711 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.73s
2020-06-21 00:51:13,737 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.81s
Cause this?
Running latest Octoprint server on RBP4 4GB. The print shifted on the Y-axis at least 4 times during the print. I am clueless. (Serial logging not available unfortunally)
Anyone with a plausible explanation?
