Background
I've have two Octoprint instances running in Docker containers (so, I'm not using OctoPi... just plain Raspbian) using plain old USB cameras through mjpg-streamer, but I wanted to start using hardware H264 encoding to lower the load on my Pi, so I bought some generic H264 USB cams and am trying to get going with those.
lsusb reports:
32e4:9422 H264 USB Camera H264 USB Camera
while v4l2-ctl on the four device files report:
v4l2-ctl -d /dev/v4l/by-id/usb-H264_USB_Camera_H264_USB_Camera_2020032801-video-index0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
[1]: 'YUYV' (YUYV 4:2:2)
v4l2-ctl -d /dev/v4l/by-id/usb-H264_USB_Camera_H264_USB_Camera_2020032801-video-index1 --list-formats
Type: Video Capture
v4l2-ctl -d /dev/v4l/by-id/usb-H264_USB_Camera_H264_USB_Camera_2020032801-video-index2 --list-formats
Type: Video Capture
[0]: 'H264' (H.264, compressed)
v4l2-ctl -d /dev/v4l/by-id/usb-H264_USB_Camera_H264_USB_Camera_2020032801-video-index3 --list-formats
Type: Video Capture
I read a lot of Low-Latency H264 Streaming Support w/ WebRTC to try to make sense of it, but it's unclear what service I'm supposed to run in order to achieve this. I've looked for WebRTC daemons for raspi, and found one, but it seems to be aimed at video-conferencing and streaming of various non-camera sources.
I also found camera-streamer, and I was able to get that to stream from the non-H264 device, but I can't get it to just do plain pass-through of the H264 stream to a web client.
No. This isn't even to the step where I point OctoPrint at a stream URL. I'm just trying to get my system to stream the hardware H264 stream in a way that OctoPrint could even consume. I realize that this isn't technically an OctoPrint issue, but it's a problem that I'm sure counteless OctoPrint users have solved and must have a standard solution, but, for the life of me, I can't find it.
octoprint-systeminfo-20231201230315.zip (37.2 KB)
OctoPrint 1.9.3 on a RasPi 4b running Raspbian bookworm on kernel 6.1.63
