My Suggestion
I would like to propose an update to Octoprint, to improve accuracy of total and layer print estimates.
The estimates can be made a lot more accurate by:
- At start of print job, counting the total number of GCode commands
- Constantly measuring actual time taken to print each layer
- Maintaining an internal mathematical model of average GCode commands per second, and keeping this model updated
- Updating the displayed time estimates -- total print time, and layer print time, based on the empirical average of GCode commands executed per second
Also, it would be great to have displayed estimates of:
- Total filament required, in metres
- Remaining filament required, in metres, to complete the current job
- Average filament consumption rate, in metres per hour
When printing to my Creality CR-10 Max, the time estimates given by OctoPrint UI (both total print time and layer print times) are very inaccurate for almost the entire print.
The total print time only starts converging to accuracy when the print is almost complete.
I work around the problem by using a stopwatch to measure how long each layer takes to print, then comparing that with the Octoprint layer print time estimate, and converting this to a multiplier.
I don't think this is applicable. Octoprint works, and it's just a time estimates calculation problem.
Not applicable.
Zip file is here available to download
Nothing else afaik
