Hi guys,
I have problem with switching my printer light on/off via smartphone apps like OctoClient or OctoPod. If I use OctoPrint web interface it works fine. But if I'd like to use commands via app it doesn't work at all - nothing happens.
I had long time conversation with OctoClient support, but without getting my problem solved. After that I tried another app called OctoPod and guess what - same issue within this app. The commands are shown in the menu but there is no action after clicking.
Here are my system facts at all:
Ender 3 Pro
RaspberryPi 3 B+
OctoPrint 1.3.11 (actual 1.3.12)
iPhone XR with iOS 12.1 (actual 13.1.1)
OctoClient v 3.0.4 (42)
OctoPod v 2.8 build 2
Here are the part of the ~/.octoprint/config.yaml
system:
actions:
- action: mainlight on
command: /usr/local/bin/gpio -g write 17 1
name: Hauptbeleuchtung einschalten
- action: mainlight off
command: /usr/local/bin/gpio -g write 17 0
name: Hauptbeleuchtung ausschalten
I checked octoprint.log about any command response โฆ this is the "old" log:
2019-08-05 11:33:25,728 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-08-05 11:33:55,781 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-08-05 11:34:25,841 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-08-05 11:34:46,270 - octoprint.server.api.system - INFO - Performing command for custom:mainlight on
2019-08-05 11:34:53,107 - octoprint.server.api.system - INFO - Performing command for custom:mainlight off
2019-08-05 11:34:55,896 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-08-05 11:34:58,310 - tornado.access - WARNING - 403 GET /sockjs/websocket (::ffff:10.10.0.20) 1.81ms
2019-08-05 11:35:25,959 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-08-05 11:35:49,670 - tornado.access - WARNING - 403 GET /sockjs/websocket (::ffff:10.10.0.20) 2.17ms
2019-08-05 11:35:56,012 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-08-05 11:36:26,069 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
First I tried to switch light via web interface and it worked @ 11:34:46
After that I tried to switch light via app 3 times and no entry was created. I thought the tornado.access WARNING was created due the issue, but after the third try there is no additional tornado.access entry - so I think this is another โissueโ?!
Anyway... with web interface everything works fine ...
Any guess? Any help?
