System commands in OctoPrint menu, installed on OctoPi, doesn't work at all despite spawning a notification stating the operation is succesful.
Octoprint logs mention something about missing terminal
2024-11-23 21:47:02,738 - octoprint.server.api.system - WARNING - Command for core:reboot failed with return code 1:
! STDOUT:
! STDERR:
! sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
! sudo: a password is required
Checked the sudo group, checked the sudoers.d config, tried running the commands manually from ssh (works)
Yes
No, it didn't
octoprint-systeminfo-20241123214811.zip (421.6 KB)
OctoPrint 1.10.3
OctoPi 1.0.0cam (build 2024.11.05.100055)
