The problem is that when I start a print octoprint goes through its start-up Gcode that I have built and heats bed to 75 and hotend to 240. Once that is all done then it will start the gcode file or 3D print at this point the bed temp drops to 65 and the hot end drops to 195 watch is my settings for my PLA.
#2
I have got it down to its something to do with octoprint. I have tried running the same gcode or print off of pronterface and works with no problem no fulling temp to PLA heat.
I have tried running it with no start-up gcode. I have deleted all the plugins that I think would mess up temp adjustments.
I have tried it in Safe mode and this still happens.
I have it running off of simplify 3D manually it has a built-in machine controller software and it runs fine. but running it from octoprint safe mode still changing temp values?
Because simplify 3D is putting those other temp values in the Gcode. Not octoprint
Save the Gcode from simplify3d to an SD card and pop that in the printer with octoprint disconnected. You'll get the same result
I have tried that and do not get the same results?.....I have to say Octoprint is a love hate relationship with me, I just reinstalled Octoprint on a new SD card and have no problems with temp adjusting at beginning of print. I was hoping that safe mode on octoprint would help in this situation but did not. It seems like ever time I get a new update for octoprint or a plugin a new problem occurs.
I just assume this:
The first temperatures are set in S3D start code and when it comes to printing, S3D inserts the temperature values that are set for the used filament.
