Hi, I added a Pi with Octoprint to my Ender 6 running a BTT mainboard with Marlin firmware. When I start a print using the screen, it works just fine. But when I start a print from Octoprint, the following happens:
- Printer heats bed to 60 and nozzle to 150
- Printer starts probing (BLTOUCH)
- Just before the first layer, the printer should heat to 195 (which is stated in the GCODE file), but instead the printer heats to 170 degrees and beeps at me because it's preventing cold extrusion.
Tried printing the same GCODE file from the printer screen, that works. It doesn't matter what nozzle temperature I use in my slicer, it's being changed to 170 degrees when I use octoprint.
This is the start of my gcode file, I don't think this is the problem:
M201 X5000 Y5000 Z100 E1000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z10 E100 ; sets maximum feedrates, mm/sec
M204 P200 R1000 T200 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X10.00 Y10.00 Z0.30 E0.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
;TYPE:Custom
G90 ; use absolute coordinates
M83 ; extruder relative mode
M104 S150 ; set extruder temp for auto bed leveling
M140 S60 ; set bed temp
M190 S60 ; wait for bed temp
G28 ; home all
G29 ; auto bed levelling
G1 Z50 F240
G1 X2 Y10 F3000
M104 S195 ; set extruder temp
M109 S195 ; wait for extruder temp
G1 Z0.28 F240
G92 E0
G1 Y190 E15 F1500 ; intro line
Serial.log which shows that the temp target changes to 170 before the first layer:
2021-02-19 13:07:28,579 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-19 13:07:28,622 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
2021-02-19 13:07:28,623 - Trying port /dev/ttyACM0, baudrate 115200
2021-02-19 13:07:28,624 - Connecting to port /dev/ttyACM0, baudrate 115200
2021-02-19 13:07:28,630 - Handshake attempt #1 with timeout 2.0s
2021-02-19 13:07:28,632 - Connected to: Serial<id=0x72f23870, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2021-02-19 13:07:28,635 - Send: N0 M110 N0*125
2021-02-19 13:07:30,638 - Handshake attempt #2 with timeout 2.0s
2021-02-19 13:07:30,653 - Send: N0 M110 N0*125
2021-02-19 13:07:32,523 - Recv: DIGIPOTS Loading
2021-02-19 13:07:32,530 - Recv: DIGIPOTS Loaded
2021-02-19 13:07:33,762 - Recv: DIGIPOTS Loading
2021-02-19 13:07:33,764 - Handshake attempt #3 with timeout 2.0s
2021-02-19 13:07:33,778 - Send: N0 M110 N0*125
2021-02-19 13:07:33,781 - Recv: DIGIPOTS Loaded
2021-02-19 13:07:33,840 - Recv: echo:V82 stored settings retrieved (646 bytes; crc 243)
2021-02-19 13:07:35,500 - Recv: Testing X connection... OK
2021-02-19 13:07:35,509 - Recv: Testing Y connection... OK
2021-02-19 13:07:35,515 - Recv: Testing Z connection... OK
2021-02-19 13:07:35,518 - Recv: Testing E connection... OK
2021-02-19 13:07:36,014 - Recv: echo:SD card ok
2021-02-19 13:07:36,019 - Trying port /dev/ttyACM0, baudrate 250000
2021-02-19 13:07:36,032 - Handshake attempt #1 with timeout 2.0s
2021-02-19 13:07:36,039 - Recv: ok
2021-02-19 13:07:36,043 - Send: N0 M110 N0*125
2021-02-19 13:07:36,049 - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-02-19 13:07:36,127 - Recv: ok
2021-02-19 13:07:36,129 - Recv: ok
2021-02-19 13:07:36,131 - Recv: ok
2021-02-19 13:07:36,133 - Send: N0 M110 N0*125
2021-02-19 13:07:36,165 - Recv: ok
2021-02-19 13:07:36,177 - Send: N1 M115*39
2021-02-19 13:07:36,248 - Recv: FIRMWARE_NAME:Marlin 2.0.7.2 (Feb 17 2021 20:20:58) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-5 Plus EXTRUDER_COUNT:1 UUID:5a37052e-424e-4819-8efe-d9ce53788ab2
2021-02-19 13:07:36,251 - Recv: Cap:SERIAL_XON_XOFF:0
2021-02-19 13:07:36,254 - Recv: Cap:BINARY_FILE_TRANSFER:0
2021-02-19 13:07:36,267 - Recv: Cap:EEPROM:1
2021-02-19 13:07:36,276 - Recv: Cap:VOLUMETRIC:1
2021-02-19 13:07:36,280 - Recv: Cap:AUTOREPORT_TEMP:1
2021-02-19 13:07:36,286 - Recv: Cap:PROGRESS:0
2021-02-19 13:07:36,291 - Recv: Cap:PRINT_JOB:1
2021-02-19 13:07:36,298 - Recv: Cap:AUTOLEVEL:1
2021-02-19 13:07:36,304 - Recv: Cap:RUNOUT:1
2021-02-19 13:07:36,309 - Recv: Cap:Z_PROBE:1
2021-02-19 13:07:36,314 - Recv: Cap:LEVELING_DATA:1
2021-02-19 13:07:36,319 - Recv: Cap:BUILD_PERCENT:1
2021-02-19 13:07:36,323 - Recv: Cap:SOFTWARE_POWER:0
2021-02-19 13:07:36,326 - Recv: Cap:TOGGLE_LIGHTS:0
2021-02-19 13:07:36,330 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2021-02-19 13:07:36,334 - Recv: Cap:EMERGENCY_PARSER:0
2021-02-19 13:07:36,338 - Recv: Cap:PROMPT_SUPPORT:0
2021-02-19 13:07:36,341 - Recv: Cap:SDCARD:1
2021-02-19 13:07:36,345 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2021-02-19 13:07:36,348 - Recv: Cap:LONG_FILENAME:1
2021-02-19 13:07:36,353 - Recv: Cap:THERMAL_PROTECTION:1
2021-02-19 13:07:36,359 - Recv: Cap:MOTION_MODES:0
2021-02-19 13:07:36,363 - Recv: Cap:ARCS:1
2021-02-19 13:07:36,368 - Recv: Cap:BABYSTEPPING:1
2021-02-19 13:07:36,373 - Recv: Cap:CHAMBER_TEMPERATURE:0
2021-02-19 13:07:36,379 - Recv: ok
2021-02-19 13:07:36,381 - Send: M20
2021-02-19 13:07:36,384 - Recv: Begin file list
2021-02-19 13:07:36,388 - Recv: End file list
2021-02-19 13:07:36,390 - Recv: ok
2021-02-19 13:07:36,392 - Send: M420V1
2021-02-19 13:07:36,398 - Recv: Bed Level Correction Matrix:
2021-02-19 13:07:36,400 - Recv: +1.000000 +0.000000 -0.000110
2021-02-19 13:07:36,402 - Recv: +0.000000 +1.000000 +0.000684
2021-02-19 13:07:36,404 - Recv: +0.000110 -0.000684 +1.000000
2021-02-19 13:07:36,405 - Recv: echo:Bed Leveling OFF
2021-02-19 13:07:36,408 - Recv: ok
2021-02-19 13:07:36,410 - Send: M851
2021-02-19 13:07:36,414 - Recv: Probe Offset X-20.70 Y-7.00 Z-2.95
2021-02-19 13:07:36,416 - Recv: ok
2021-02-19 13:07:36,417 - Send: M155 S2
2021-02-19 13:07:36,419 - Recv: ok
2021-02-19 13:07:38,430 - Recv: T:90.81 /0.00 B:58.93 /0.00 @:0 B@:0
2021-02-19 13:07:40,423 - Recv: T:89.87 /0.00 B:58.80 /0.00 @:0 B@:0
2021-02-19 13:07:42,423 - Recv: T:88.93 /0.00 B:58.78 /0.00 @:0 B@:0
2021-02-19 13:07:42,990 - Changing monitoring state from "Operational" to "Starting"
2021-02-19 13:07:43,072 - Send: N0 M110 N0*125
2021-02-19 13:07:43,081 - Recv: ok
2021-02-19 13:07:43,082 - Changing monitoring state from "Starting" to "Printing"
2021-02-19 13:07:43,088 - Send: N1 M201 X5000 Y5000 Z100 E1000*15
2021-02-19 13:07:43,091 - Recv: ok
2021-02-19 13:07:43,093 - Send: N2 M203 X500 Y500 Z10 E100*14
2021-02-19 13:07:43,097 - Recv: ok
2021-02-19 13:07:43,099 - Send: N3 M204 P200 R1000 T200*81
2021-02-19 13:07:43,101 - Recv: ok
2021-02-19 13:07:43,103 - Send: N4 M205 X10.00 Y10.00 Z0.30 E0.50*56
2021-02-19 13:07:43,105 - Recv: ok
2021-02-19 13:07:43,107 - Send: N5 M205 S0 T0*38
2021-02-19 13:07:43,109 - Recv: ok
2021-02-19 13:07:43,111 - Send: N6 M107*35
2021-02-19 13:07:43,112 - Recv: ok
2021-02-19 13:07:43,114 - Send: N7 G90*23
2021-02-19 13:07:43,118 - Recv: ok
2021-02-19 13:07:43,121 - Send: N8 M83*16
2021-02-19 13:07:43,123 - Recv: ok
2021-02-19 13:07:43,127 - Send: N9 M104 S150*104
2021-02-19 13:07:43,131 - Recv: ok
2021-02-19 13:07:43,133 - Send: N10 M140 S60*98
2021-02-19 13:07:43,137 - Recv: ok
2021-02-19 13:07:43,140 - Send: N11 M190 S60*110
2021-02-19 13:07:43,146 - Recv: T:88.62 /150.00 B:58.78 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:44,147 - Recv: T:88.23 /150.00 B:58.67 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:44,423 - Recv: T:88.12 /150.00 B:58.76 /60.00 @:127 B@:0
2021-02-19 13:07:45,146 - Recv: T:87.84 /150.00 B:58.57 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:45,156 - Recv: echo:busy: processing
2021-02-19 13:07:45,159 - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-02-19 13:07:46,146 - Recv: T:87.71 /150.00 B:58.53 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:46,423 - Recv: T:87.70 /150.00 B:58.55 /60.00 @:127 B@:0
2021-02-19 13:07:47,147 - Recv: T:87.81 /150.00 B:58.50 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:47,156 - Recv: echo:busy: processing
2021-02-19 13:07:48,147 - Recv: T:88.25 /150.00 B:58.50 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:48,423 - Recv: T:88.35 /150.00 B:58.49 /60.00 @:127 B@:0
2021-02-19 13:07:49,146 - Recv: T:89.00 /150.00 B:58.45 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:49,155 - Recv: echo:busy: processing
2021-02-19 13:07:50,146 - Recv: T:90.00 /150.00 B:58.35 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:50,424 - Recv: T:90.38 /150.00 B:58.42 /60.00 @:127 B@:0
2021-02-19 13:07:51,147 - Recv: T:91.16 /150.00 B:58.33 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:51,155 - Recv: echo:busy: processing
2021-02-19 13:07:52,147 - Recv: T:92.80 /150.00 B:58.35 /60.00 @:127 B@:0 W:?
2021-02-19 13:07:52,423 - Recv: T:93.03 /150.00 B:58.31 /60.00 @:127 B@:15
2021-02-19 13:07:53,147 - Recv: T:94.32 /150.00 B:58.22 /60.00 @:127 B@:80 W:?
2021-02-19 13:07:53,157 - Recv: echo:busy: processing
2021-02-19 13:07:54,147 - Recv: T:96.05 /150.00 B:58.20 /60.00 @:127 B@:127 W:?
2021-02-19 13:07:54,424 - Recv: T:96.64 /150.00 B:58.22 /60.00 @:127 B@:127
2021-02-19 13:07:55,148 - Recv: T:97.80 /150.00 B:58.19 /60.00 @:127 B@:127 W:?
2021-02-19 13:07:55,156 - Recv: echo:busy: processing
2021-02-19 13:07:56,151 - Recv: T:99.97 /150.00 B:58.16 /60.00 @:127 B@:127 W:?
2021-02-19 13:07:56,423 - Recv: T:100.22 /150.00 B:58.16 /60.00 @:127 B@:127
2021-02-19 13:07:57,147 - Recv: T:101.89 /150.00 B:58.07 /60.00 @:127 B@:127 W:?
2021-02-19 13:07:57,156 - Recv: echo:busy: processing
2021-02-19 13:07:58,147 - Recv: T:103.69 /150.00 B:58.19 /60.00 @:127 B@:127 W:?
2021-02-19 13:07:58,423 - Recv: T:104.33 /150.00 B:58.23 /60.00 @:127 B@:127
2021-02-19 13:07:59,147 - Recv: T:105.62 /150.00 B:58.16 /60.00 @:127 B@:127 W:?
2021-02-19 13:07:59,154 - Recv: echo:busy: processing
2021-02-19 13:08:00,147 - Recv: T:107.95 /150.00 B:58.35 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:00,423 - Recv: T:108.25 /150.00 B:58.33 /60.00 @:127 B@:127
2021-02-19 13:08:01,147 - Recv: T:109.84 /150.00 B:58.40 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:01,159 - Recv: echo:busy: processing
2021-02-19 13:08:02,154 - Recv: T:111.87 /150.00 B:58.37 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:02,423 - Recv: T:112.52 /150.00 B:58.41 /60.00 @:127 B@:127
2021-02-19 13:08:03,149 - Recv: echo:busy: processing
2021-02-19 13:08:03,165 - Recv: T:113.84 /150.00 B:58.52 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:04,163 - Recv: T:116.15 /150.00 B:58.57 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:04,423 - Recv: T:116.48 /150.00 B:58.62 /60.00 @:127 B@:127
2021-02-19 13:08:05,149 - Recv: echo:busy: processing
2021-02-19 13:08:05,163 - Recv: T:118.09 /150.00 B:58.75 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:06,163 - Recv: T:120.01 /150.00 B:58.74 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:06,423 - Recv: T:120.66 /150.00 B:58.87 /60.00 @:127 B@:127
2021-02-19 13:08:07,149 - Recv: echo:busy: processing
2021-02-19 13:08:07,164 - Recv: T:121.97 /150.00 B:58.96 /60.00 @:127 B@:127 W:?
2021-02-19 13:08:08,164 - Recv: T:124.15 /150.00 B:59.17 /60.00 @:127 B@:127 W:9
2021-02-19 13:08:08,423 - Recv: T:124.46 /150.00 B:59.17 /60.00 @:127 B@:127
2021-02-19 13:08:09,148 - Recv: echo:busy: processing
2021-02-19 13:08:09,164 - Recv: T:126.04 /150.00 B:59.18 /60.00 @:127 B@:127 W:8
2021-02-19 13:08:10,164 - Recv: T:127.96 /150.00 B:59.38 /60.00 @:127 B@:127 W:7
2021-02-19 13:08:10,423 - Recv: T:128.56 /150.00 B:59.38 /60.00 @:127 B@:127
2021-02-19 13:08:11,148 - Recv: echo:busy: processing
2021-02-19 13:08:11,164 - Recv: T:129.79 /150.00 B:59.57 /60.00 @:127 B@:120 W:6
2021-02-19 13:08:12,164 - Recv: T:131.66 /150.00 B:59.62 /60.00 @:127 B@:122 W:5
2021-02-19 13:08:12,424 - Recv: T:132.21 /150.00 B:59.64 /60.00 @:127 B@:123
2021-02-19 13:08:13,148 - Recv: echo:busy: processing
2021-02-19 13:08:13,164 - Recv: T:133.74 /150.00 B:59.83 /60.00 @:127 B@:103 W:4
2021-02-19 13:08:14,164 - Recv: T:135.51 /150.00 B:59.96 /60.00 @:127 B@:94 W:3
2021-02-19 13:08:14,424 - Recv: T:136.15 /150.00 B:60.00 /60.00 @:127 B@:92
2021-02-19 13:08:15,149 - Recv: echo:busy: processing
2021-02-19 13:08:15,164 - Recv: T:137.37 /150.00 B:60.08 /60.00 @:127 B@:87 W:2
2021-02-19 13:08:16,164 - Recv: T:139.25 /150.00 B:60.14 /60.00 @:127 B@:87 W:1
2021-02-19 13:08:16,424 - Recv: T:139.77 /150.00 B:60.28 /60.00 @:127 B@:69
2021-02-19 13:08:17,148 - Recv: echo:busy: processing
2021-02-19 13:08:17,164 - Recv: T:141.25 /150.00 B:60.42 /60.00 @:127 B@:54 W:0
2021-02-19 13:08:17,512 - Recv: ok
2021-02-19 13:08:17,516 - Send: N12 M113 S2*82
2021-02-19 13:08:18,425 - Recv: T:143.58 /150.00 B:60.53 /60.00 @:87 B@:42
2021-02-19 13:08:19,513 - Recv: echo:busy: processing
2021-02-19 13:08:20,424 - Recv: T:146.90 /150.00 B:60.74 /60.00 @:34 B@:15
2021-02-19 13:08:21,513 - Recv: echo:busy: processing
2021-02-19 13:08:22,424 - Recv: T:149.69 /150.00 B:60.95 /60.00 @:0 B@:0
2021-02-19 13:08:23,513 - Recv: echo:busy: processing
2021-02-19 13:08:25,162 - Recv: T:151.97 /150.00 B:61.09 /60.00 @:0 B@:0
2021-02-19 13:08:25,513 - Recv: echo:busy: processing
2021-02-19 13:08:28,521 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-02-19 13:08:28,525 - Send: N13 M105*21
2021-02-19 13:08:28,747 - Recv: echo:busy: processing
2021-02-19 13:08:28,761 - Recv: T:152.16 /150.00 B:61.16 /60.00 @:0 B@:0
2021-02-19 13:08:30,747 - Recv: echo:busy: processing
2021-02-19 13:08:30,763 - Recv: T:151.30 /150.00 B:61.08 /60.00 @:3 B@:0
2021-02-19 13:08:32,747 - Recv: echo:busy: processing
2021-02-19 13:08:32,762 - Recv: T:150.12 /150.00 B:61.15 /60.00 @:28 B@:0
2021-02-19 13:08:34,753 - Recv: echo:busy: processing
2021-02-19 13:08:34,763 - Recv: T:148.84 /150.00 B:61.10 /60.00 @:56 B@:0
2021-02-19 13:08:36,752 - Recv: echo:busy: processing
2021-02-19 13:08:36,765 - Recv: T:147.65 /150.00 B:61.09 /60.00 @:82 B@:0
2021-02-19 13:08:36,795 - Recv: X:150.70 Y:137.00 Z:17.00 E:0.00 Count A:23016 B:1096 Z:6800
2021-02-19 13:08:38,753 - Recv: echo:busy: processing
2021-02-19 13:08:38,764 - Recv: T:146.96 /150.00 B:61.01 /60.00 @:97 B@:0
2021-02-19 13:08:39,857 - Recv: X:18.00 Y:249.00 Z:20.00 E:0.00 Count A:21360 B:-18480 Z:8000
2021-02-19 13:08:40,752 - Recv: echo:busy: processing
2021-02-19 13:08:40,766 - Recv: T:146.91 /170.00 B:60.95 /60.00 @:127 B@:0
2021-02-19 13:08:42,753 - Recv: echo:busy: processing
2021-02-19 13:08:42,766 - Recv: T:147.57 /170.00 B:60.91 /60.00 @:127 B@:0
2021-02-19 13:08:44,753 - Recv: echo:busy: processing
2021-02-19 13:08:44,766 - Recv: T:149.11 /170.00 B:60.82 /60.00 @:127 B@:0
2021-02-19 13:08:46,752 - Recv: echo:busy: processing
2021-02-19 13:08:46,768 - Recv: T:151.17 /170.00 B:60.73 /60.00 @:127 B@:0
2021-02-19 13:08:48,752 - Recv: echo:busy: processing
2021-02-19 13:08:48,765 - Recv: T:153.87 /170.00 B:60.74 /60.00 @:127 B@:0
2021-02-19 13:08:50,752 - Recv: echo:busy: processing
2021-02-19 13:08:50,768 - Recv: T:156.65 /170.00 B:60.56 /60.00 @:127 B@:0
2021-02-19 13:08:52,753 - Recv: echo:busy: processing
2021-02-19 13:08:52,772 - Recv: T:159.42 /170.00 B:60.57 /60.00 @:127 B@:0
2021-02-19 13:08:54,753 - Recv: echo:busy: processing
2021-02-19 13:08:54,771 - Recv: T:162.93 /170.00 B:60.50 /60.00 @:101 B@:0
2021-02-19 13:08:56,753 - Recv: echo:busy: processing
2021-02-19 13:08:56,771 - Recv: T:165.99 /170.00 B:60.44 /60.00 @:53 B@:0
2021-02-19 13:08:58,753 - Recv: echo:busy: processing
2021-02-19 13:08:58,771 - Recv: T:168.87 /170.00 B:60.32 /60.00 @:12 B@:0
2021-02-19 13:09:01,784 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-02-19 13:09:01,789 - Send: N14 M105*18
2021-02-19 13:09:04,233 - Recv: echo:busy: processing
2021-02-19 13:09:04,243 - Recv: T:171.62 /170.00 B:59.96 /60.00 @:0 B@:18
2021-02-19 13:09:06,232 - Recv: echo:busy: processing
2021-02-19 13:09:06,244 - Recv: T:170.76 /170.00 B:60.00 /60.00 @:20 B@:6
2021-02-19 13:09:08,232 - Recv: echo:busy: processing
2021-02-19 13:09:08,243 - Recv: T:169.65 /170.00 B:59.67 /60.00 @:48 B@:50
2021-02-19 13:09:10,236 - Recv: T:168.39 /170.00 B:59.79 /60.00 @:78 B@:31
2021-02-19 13:09:10,253 - Recv: echo:busy: processing
2021-02-19 13:09:12,236 - Recv: T:167.48 /170.00 B:59.67 /60.00 @:98 B@:49
2021-02-19 13:09:12,250 - Recv: echo:busy: processing
2021-02-19 13:09:14,245 - Recv: T:167.10 /170.00 B:59.57 /60.00 @:107 B@:67
2021-02-19 13:09:14,254 - Recv: echo:busy: processing
2021-02-19 13:09:15,747 - Recv: echo:Insert filament and press button
2021-02-19 13:09:16,244 - Recv: T:167.40 /170.00 B:59.62 /60.00 @:102 B@:66
2021-02-19 13:09:16,253 - Recv: echo:busy: paused for user
2021-02-19 13:09:18,244 - Recv: T:168.32 /170.00 B:59.58 /60.00 @:84 B@:79
2021-02-19 13:09:18,260 - Recv: echo:busy: paused for user
2021-02-19 13:09:20,244 - Recv: T:169.44 /170.00 B:59.62 /60.00 @:63 B@:84
2021-02-19 13:09:20,254 - Recv: echo:busy: paused for user
2021-02-19 13:09:22,245 - Recv: T:170.70 /170.00 B:59.74 /60.00 @:38 B@:77
2021-02-19 13:09:22,259 - Recv: echo:busy: paused for user
2021-02-19 13:09:24,245 - Recv: T:171.86 /170.00 B:59.77 /60.00 @:15 B@:84
2021-02-19 13:09:24,262 - Recv: echo:busy: paused for user
2021-02-19 13:09:26,245 - Recv: T:172.17 /170.00 B:59.91 /60.00 @:11 B@:72
2021-02-19 13:09:26,263 - Recv: echo:busy: paused for user
2021-02-19 13:09:28,245 - Recv: T:172.05 /170.00 B:60.00 /60.00 @:14 B@:66
2021-02-19 13:09:28,261 - Recv: echo:busy: paused for user
2021-02-19 13:09:30,245 - Recv: T:171.27 /170.00 B:60.15 /60.00 @:32 B@:50
2021-02-19 13:09:30,259 - Recv: echo:busy: paused for user
2021-02-19 13:09:32,245 - Recv: T:170.29 /170.00 B:60.28 /60.00 @:51 B@:35
2021-02-19 13:09:32,265 - Recv: echo:busy: paused for user
2021-02-19 13:09:34,245 - Recv: T:169.41 /170.00 B:60.36 /60.00 @:68 B@:24
2021-02-19 13:09:34,260 - Recv: echo:busy: paused for user
2021-02-19 13:09:36,245 - Recv: T:168.65 /170.00 B:60.45 /60.00 @:82 B@:6
2021-02-19 13:09:36,261 - Recv: echo:busy: paused for user
2021-02-19 13:09:38,245 - Recv: T:168.33 /170.00 B:60.51 /60.00 @:88 B@:0
2021-02-19 13:09:38,261 - Recv: echo:busy: paused for user
2021-02-19 13:09:40,245 - Recv: T:168.51 /170.00 B:60.50 /60.00 @:83 B@:0
2021-02-19 13:09:40,258 - Recv: echo:busy: paused for user
2021-02-19 13:09:42,245 - Recv: T:169.13 /170.00 B:60.60 /60.00 @:70 B@:0
2021-02-19 13:09:42,260 - Recv: echo:busy: paused for user
2021-02-19 13:09:44,249 - Recv: T:169.84 /170.00 B:60.59 /60.00 @:55 B@:0
2021-02-19 13:09:44,264 - Recv: echo:busy: paused for user
2021-02-19 13:09:46,248 - Recv: T:170.70 /170.00 B:60.49 /60.00 @:38 B@:0
2021-02-19 13:09:46,263 - Recv: echo:busy: paused for user
2021-02-19 13:09:48,248 - Recv: T:171.27 /170.00 B:60.44 /60.00 @:27 B@:0
2021-02-19 13:09:48,264 - Recv: echo:busy: paused for user
2021-02-19 13:09:50,248 - Recv: T:171.56 /170.00 B:60.41 /60.00 @:22 B@:0
2021-02-19 13:09:50,264 - Recv: echo:busy: paused for user
2021-02-19 13:09:52,248 - Recv: T:171.39 /170.00 B:60.32 /60.00 @:26 B@:0
2021-02-19 13:09:52,266 - Recv: echo:busy: paused for user
2021-02-19 13:09:54,059 - Connection closed, closing down monitor
2021-02-19 13:09:54,072 - Changing monitoring state from "Printing" to "Offline"
Any help would be appreciated!
