Printer
Anycubic Predator
Unable to start print, start looping error message in terminal
After that, unable to cancel print
After that, unable to lower temperature, still looping the same error message
What is working
Able to reboot octoprint after the error
Raising temperature
Lowering temperature (before the print error appears)
Error code
Recv: //callback_pf error
Recv: //sd cmd error cnt:35307 len:45 :N11 M104 S200 set temp to 200 (removed)115
Recv:
Recv: ok
Send: N12 G2832
Recv: Resend:11
Recv: //last:10 curr:12 rcv:N12 G28*32
Send: N11 M104 S200 set temp to 200 (removed)*115
Recv:
I have tried printing a model with 200 degree hotend and one with 205 degree, both showed the same error message.
logs below:
octoprint (1).zip (167.1 KB)
