I just updated to the latest version of Octoprint today and on my Ender 3 S1 Plus the extruder does not start heating until the bed has reached the set point. Then the extruder starts to heat. On previous version they both started heating at the same time.
Nothing it worked prior to this latest upgrade.
NO
N/A
My printer is an Ender 3 S1 Plus running on a Laptop as a print server with Ubuntu and OctoPrint. Also remotely connect o the lap top server from my Windows PC upstairs.
Before I did the upgarde they both started at the same time. I did not change anything.
I thought the temp settings come from CURA into the G.Code. I change the nozzle temp in CURA based on printing very light or very dark colors.
Here is my start code from CURA.
--------Machine Config--------------
;Machine Name:Creality Ender-3 S1 Plus
G28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
I dont think its going to be in the start code. That does not sound right. But the slicer would be the place this gcode comes from under normal operation.
I think @Ewald_Ikemann is likely right that you had some plugin that enabled the hot end and the bed to heat at the same time but... I also am thinking that its very normal and maybe even necessary for the bed to heat up first. I recall something about the way Marlin handles the commands.. It can only really do one at a time and if you tell it to not wait for the first command (heat the bed) before you say move on and (heat the hot end) you are creating a race between the 2 where once the second command finishes (Hot end met temp) you will find that it tries to start to print.
Could be wrong here but every printer I have running marlin with slice from Cura does the bed and then the hot end.
Both the bed and the nozzle have two commands to control the temperature, one that waits and one that doesn't. M104 and M109 for the nozzle and M140 and M190 for the bed. The sequence:
M104 S200 ; Start the nozzle
M140 S60 ; Start the bed
M109 S200 ; Wait for the nozzle
M190 S60 ; Wait for the bed
will heat both the nozzle and the bed at the same time. Note that there are additional parameters for M109 and M190 that can fine tune the temperature journey.
This, of course, has nothing to do with the original problem but upgrading OctoPrint from 1.9.0 to 1.9.1 probably has nothing to do with the original problem either.
Also I am unable to manually edit the hot end temperature in Octoprint. I can manually edit it for the bed.
They would both heat at the same time before I upgraded Octoprint. See my screen shot that shows the hot end as off. I am not even able to adjust the hot end manually until the bed is to the set limit. I was always able to do this before the update as I wanted to get a head start on the heating while I set up the print. You can see in the graph that the hot end set point doesn't go up until the bed temp is reached.
I just tested trying to manually set the bed temp first and then the hot end and it worked and both heat up at the same time and starts to print when the temps are reached.
Still having same issue if I start the print from Octoprint (with no manual temp settings) the hot end waits until the bed is reached before it starts to heat.
I really appreciate all the help guys. I am a bit of a newbie but learning fast.
Have you also updated Cura? What version of Cura are you using?
Assuming that you are using Ultimaker Cura 5.3.1, it has a "feature" that if there are no temperature commands in the start gcode, it will generate its own and output them before the start gcode. To solve your problem, change your start gcode to:
; Ender 3 S1 Plus Start G-code
M140 S{material_bed_temperature_layer_0} ; start bed heating up
M109 R{material_print_temperature_layer_0} ; wait for extruder to reach printing temp
M190 R{material_bed_temperature_layer_0} ; wait for bed to reach printing temp
G28 ;Home
