If I go to OctoPrint Settings-> Temperature-> Presets and try to add a preset to the list, ie- PLA 220c (extruder) 60c (Bed), on main page I can select it on Temperature tab but it always heats up to defaults. I tried deleting the default listed but it still goes back to 200c ex - 60c bed. I always use Octoprint and never use SD card. Is it something I need to set in the gcode? I am a novice and am trying to learn as I go.
What did you already try to solve it? Listed above
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, octoprint.log, serial.log or output on terminal tab, ...) MP Maker Select Plus - factory firmware
Thanks,
ScottZ0
=LOG= (Parsed)
2019-04-22 04:25:58,082 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-22 04:25:58,091 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2019-04-22 04:25:58,091 - octoprint.server - INFO - OctoPrint 1.3.10
2019-04-22 04:25:58,096 - octoprint.plugin.core - INFO - 20 plugin(s) registered with the system:
| Bed Visualizer (0.1.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| DisplayZ (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_displayz
| Firmware Updater (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| Fullscreen Plugin (0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| !TouchUI (0.3.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_touchui
2019-04-22 04:25:58,123 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918175744
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-04-22 04:25:58,123 - octoprint.server - INFO - ------------------------------------------------------------------------------
2019-04-22 04:26:10,557 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-04-22 04:26:10,573 - octoprint.plugin - ERROR - Error while calling plugin tracking
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/init.py", line 230, in call_plugin
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking/init.py", line 119, in on_event
self._track_printjob_event(event, payload)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking/init.py", line 237, in _track_printjob_event
sha.update(self._settings.get([b"unique_id"]))
TypeError: update() argument 1 must be string or buffer, not None
2019-04-22 04:26:10,588 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-22 04:33:25,254 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2019-04-22 04:33:25,295 - octoprint.plugin - ERROR - Error while calling plugin tracking
2019-04-22 04:33:25,355 - octoprint.plugin - ERROR - Error while calling plugin tracking
2019-04-22 04:33:45,291 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2019-04-22 04:40:58,085 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-22 04:41:09,603 - octoprint.server.api.system - INFO - Performing command for core:reboot: sudo shutdown -r now
2019-04-22 04:41:10,290 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::9417:4551:a5c1:e30
2019-04-22 04:41:10,748 - octoprint.server - INFO - Shutting down...
2019-04-22 04:41:11,001 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-04-22 04:41:11,002 - octoprint.events - INFO - Event loop shut down
2019-04-22 04:41:11,358 - octoprint.server - INFO - Goodbye!
2019-04-22 04:41:18,795 - octoprint.startup - INFO - ******************************************************************************
2019-04-22 04:41:18,797 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-04-22 04:41:18,801 - octoprint.startup - INFO - ******************************************************************************
2019-04-22 04:41:20,153 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-04-22 04:41:20,229 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-22 04:41:22,878 - octoprint.plugin.core - INFO - Plugin TouchUI (0.3.12) is disabled.
2019-04-22 04:41:24,161 - octoprint.plugin.core - INFO - Found 20 plugin(s) providing 19 mixin implementations, 23 hook handlers
2019-04-22 04:41:24,468 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-04-22 04:41:24,614 - octoprint.server - INFO - Intermediary server started
2019-04-22 04:41:24,615 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-22 04:41:25,333 - octoprint.plugin.core - INFO - Found 20 plugin(s) providing 19 mixin implementations, 23 hook handlers
2019-04-22 04:41:25,390 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-04-22 04:41:25,407 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-04-22 04:41:25,649 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-04-22 04:41:29,307 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-04-22 04:41:31,023 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-04-22 04:41:31,025 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-04-22 04:41:31,026 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-04-22 04:41:31,032 - octoprint.plugin.core - INFO - Initialized 19 plugin implementation(s)
2019-04-22 04:41:31,046 - octoprint.plugin.core - INFO - 20 plugin(s) registered with the system:
2019-04-22 04:41:31,067 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918175744
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
